Thread: roof rails
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Default roof rails
    Upon locating a Siggy with roof rails in a nearby scrapyard, i decided to have them away. I got in there with the tools, removed the headlining, loosened the curtain airbag housings, undid the 8 bolts and lifted them off. Now, my question is, why will these not be 'load bearing' when they're attached to my Siggy. I've read threads on here stating that that is the case. I looked at how they fitted on the car i took them off and it appeared that they simply bolted through a 6mm hole in the trough that runs the length of the car?
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    Quote Originally Posted by BigWilko View Post
    there not load bearing,they can be fitted to any signum and are just as
    strong as the roof bar kit that goes across the car.if you need to carry
    anything on the roof then you will need the roof bar kit thats used with the
    roof rails rather than the kit that attaches into the gutter brackets.
    there is no difference to the roof panels apart from if has sunroof or not
    this has been discussed previously on few occassions
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by andy.l View Post
    OK, well i knew the roof bar kits were different but i was just under the impression that if the rails were retro-fitted the use of said bars was not recommended. I seem to have got that wrong though
    12 Post(s)
    Trim : elite
    Year : 2011
    no m8 doesnt make any difference at all but vauxhall do specify a maximum
    weight on the roof anyway for dafety reasons so if you keep to that then it
    be fine.
    the roof bars and roof rails do mount practically in the same areas in the
    roof gutter anyway.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    myyyyyyyyyyyyy rooooooooooooooofffffffffffff railsssssssssssssssss
  1. 08 vectra estate low profile roof rails roof rack recommendations
    By david1 in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2013, 19:43
  2. Roof rails?
    By VikingLammy in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2012, 18:56
  3. fiiting roof bars on the roof rails of a vec estate 2004
    By tinus71 in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2010, 19:50
  4. Roof Rack for 2002 Vectra Estate with roof rails or Signum with Rails
    By willc01 in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2006, 18:32
