Results 1 to 10 of 20
Thread: 2.0T misfire ...from the top
    Regular Member vectra100turbo's Avatar
    manchester
    Default 2.0T misfire ...from the top
    the car was bought with the engine management light on, it was code read at time of purchace and it was showing EGT sensor ( hence me not thinking to much of the issue at the time) but drove fine other than a little rough on idle.
    after purchace i noticed air con on when turned it off it turned out to be really rough idle.
    parts replaced so far...
    EGT sensor, coils, cts, plugs, turbo, given a service.
    coils were genuine saab , cts from unipart, plugs are ngk also tried denco's.
    changing all the filters again this weekend inc fuel.
    after EGT replacement the eml has gone off and no codes since as its checked regular
    had compression test done ... unsure on accuracy of readings
    all wiring around engine been checked for breaks etc
    fried the carb cleaner spray to find leaks
    all provided negative results
    South east
    I've heard someone on here mention that their Z20NET was running roughly and it turned out to be a leaking flexi around the cat - might be worth taking it to an exhaust place, pretend you're interested in their services, get them to put it on a ramp, start the engine and look for any leaks along the whole exhaust starting at the manifold.
    manchester
    Quote Originally Posted by Rebellion View Post
    my exhaust sounds similar to the 2 boxes have given up (baffles gone ), i thought it was the sound from the misfire so if my backboxes are past it could that be an issue which may contribute
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    i would not think it would contribute to a rough idle situation though. Your turbo essentially provides the back pressure your engine requires...
    Have you changed any of your lambdas at all? Get that fuel filter changed and out of the way, if you do not have any code reading software take the battery neg ff for half hour and allow the ecu to reset therefore clearing any codes.. Give the throttle body a good clean out with carb cleaner if you haven't already, take the MAP sensor out of the boost pipe half way between the throttle body and the intercooler and wipe that off carefully.
    Run some injector cleaner through the fuel tank.
    Shame your not nearby, I next plan to be in Manchester in late June, but hopefully we can diagnose/resolve this by then..
    South east
    Found the thread about the blowing flexi and rough idling on a Z20NET, it's this one here:
    http://www.vectra-c.com/forum/showpo...2&postcount=56
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    I'd be looking at injectors next I think.. get someone with Vauxcom or TechII to do a full diag on the car and some data logging..
    also worth changing the CTS - these can cause all sorts of issues when they fail as they can overfuel etc...
    South east
    Quote Originally Posted by AntSSSS View Post
    Already done, going by his opening post
    lincolnshire
    what antssss said , get the injectors checked ! i know a guy who's **** hot at finding faults like this but he lives no where near you pal
    South east
    Quote Originally Posted by bembo449 View Post
    How's that going to help him? lol
    lincolnshire
    its not lol , but he cant be the only diag bloke in britain thats good at finding faults though can he ??
  1. misfire on 1.8
    By Lozza in forum Engine & Drivetrain
    Last Post: 9th August 2012, 23:57
  2. misfire?
    By ivesy in forum Engine & Drivetrain
    Last Post: 11th February 2011, 19:55
  3. V6 misfire?
    By lencuff in forum Engine & Drivetrain
    Last Post: 16th November 2010, 21:10
  4. 1.8 misfire
    By ricky1 in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2010, 23:09
  5. Misfire
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 20th July 2006, 16:30
vectra 2.0t misfire
z20net exhaust flexi pipe noise site:www.vectra-c.com
vauxhall 2.0 t misfire
