Thread: Temperature fluctuates
    Apr 2012
    UK
    Default Temperature fluctuates
    Hello, I have got vx signum 2006 1.9 cdti (150), the problem is that the temperature gauge and the readings in testing mode menu are sligtly different, but anyway the main problem is it takes long time to heat up ant after that the temperature just fluctuates between 79 anr 96 degrees C depens on how I'm driving, for example on a motorway it falls down and in the city it raises, I've seen many discussions about that, but didn't realize is it termostat foult or erg? what to do and what to check first?
    Thank you!!!
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Run it up to 70*c on the guage if the top pipe is hot thermostat failed.
    Failed ones will be hotter in town cause less air flow through the radiator
    Apr 2012
    UK
    so I just wait till it reaches 70 and then grab the top one pipe? what about others has to bee cold/hot?
    Regular Member djr69uk's Avatar
    Midlands
    It's the thermostat mate. I wrote a 'how 2' for this as I did it on mine. Check in the section and it should give you all you need including part number. The thermo fails open, so the rad is getting the coolant 100% of the time, hence it cools down quickly when it isn't supposed to.
    Apr 2012
    UK
    I addition can say that it rises to 98 degree and then fan cooler switches on if stationary.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by evaldas View Post
    Nothing to worry about
    I panicked when mine showed 98 on Test Mode, as the guage showed 92, but the fans did their work and cooled it down in minutes
  1. 3.2 - alternator voltage fluctuates
    By Jay-C in forum Electrical & ICE (including SatNav)
    Last Post: 1st November 2012, 14:14
  2. Temperature
    By Wolfie01 in forum Engine & Drivetrain
    Last Post: 13th February 2012, 10:34
  3. No Outside Temperature.
    By lammy1961 in forum Insignia car chat
    Last Post: 30th January 2012, 15:58
  4. max outside air temperature...
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2009, 11:03
  5. Temperature
    By nhoj in forum Engine & Drivetrain
    Last Post: 2nd February 2008, 20:28
