Thread: Vectra C Rear Lower Arm Outer Bush
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Default Vectra C Rear Lower Arm Outer Bush
    Hi all
    I just did my upper control arms and noticed my lower arms outer bush's has went too so can anyone tell me the part number or point me in the right direction to get the new bush's the ones that go onto the hub
    Thanks Mark
    South east
    I'm not 100% sure which bush you mean, but I'm guessing it might be this one:
    http://www.ebay.co.uk/itm/OPEL-VECTR...item43a110f7ef
    If that's the one, there's probably also a Powerflex version available, should you have won the lottery...
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    truth mate i dont really know what there called my self all i know is its the arm that the spring sits on and its the wheel side i need as the rubber is all cracked
    i think its this one if im wrong can some one say before i order them lol http://www.ebay.co.uk/itm/Powerflex-...=bin35ba473ca5
    Regular Member shb1988's Avatar
    Oct 2010
    sittingbourne
    2 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    Quote Originally Posted by Mark-R View Post
    Was that Correct power flex bush as I'm looking at doing mine soon.
    Stephen
    Jun 2009
    South Coast
    6 Post(s)
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    I replaced mine with upper arm outer bushes with powerflex bushes, best move as they will never wear out.
    Powerflex part number is PFR80-1211, you need two of course, one for each side.. prices vary
    this a set of two.. http://www.ebay.co.uk/itm/POWERFLEX-...item256a3058ed
    buy once and not have to worry about them again... pay less and do them again in a year or so, longer if you fortunate.
    for the lower arm outer bushes you need PFR80-1215
    http://www.ebay.co.uk/itm/POWERFLEX-...item256a3087b0
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    Oct 2010
    sittingbourne
    2 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    Thanks nige its the lower ones I need which you linked and they come in a set of 2 so bonus thanks
    Oct 2010
    sittingbourne
    2 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    What's the best way to removing the old ones?
    Jun 2009
    South Coast
    6 Post(s)
    knock up a removal tool as per the how2 mate.. I bought a bush removal tool from the bay and is disintegrated on the first bush so sent it back for a refund
    11 Post(s)
    Hi all
    Thanks Mark
    Is this the one you're on about in a previous thread of mine?
    http://www.vectra-c.com/forum/showthread.php?171693
    The bush part No is mentioned there (24469643), along with where I bought it from ( http://www.vauxhallworldparts.com/va...umber=24469643 ).
    If it is the bush you're referring to, then the bush can be changed with a Vec-B rose bush removal tool. It's a tight fit, and if you've access to a lathe you can machine out the centres to get rid of the interferance fit.
    Or you can make your own up ( http://www.vectra-c.com/forum/showth...l-Arms-Easilly ). The bush dimensions are:-
    Length: 32 mm & 52 mm (guessing the 32mm is the outer length that fits into the hub assembly, and the 52mm is the inner length of the tube the bolt goes through)
    Inner Diameter : 12 mm
    Outer Diameter : 45½ mm
    Oct 2010
    sittingbourne
    2 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    So some threaded stud (8mm) and some nuts but guessing the round bit and flat plate need to be made up?
  1. rear lower control arm bush
    By Phil in forum Suspension, Wheels & Brakes
    Last Post: 26th July 2012, 13:32
  2. Replace Outer Bush on Rear Upper Control Arms Easilly
    By Rebellion in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2012, 06:43
  3. 2005 upper, outer, rear suspension rose bush
    By kbs in forum Suspension, Wheels & Brakes
    Last Post: 8th February 2012, 20:21
vectra c lower rear control arms
https:www.vectra-c.comforumshowthread.php162070-Vectra-C-Rear-Lower-Arm-Outer-Bush
vectra c rear control arm
vectra c 55 plate bushes
lower arm inner & outer bush
vectra c rear lower arm outer bush
vectra c rear lower control arm
vectra c lower arm spline
vectra c outer hub bush
how to check rear lower arm linkeage on vectra c
do Vauxhall Vectra C have rear lower Arms
vectra c rear trailing arm
vectra c lower control bush
vectra c front control arms
rose bush vectra c
signum upper control arm bush
vauxhall signum rear lower arm
2004 vectra c rear suspension arms
vectra c lower control arm bush
vectra c rear hub bush
what bushes is it on a vectra c that makes the back wheel sit out
polyurethane bushes vectra c
vectra rear rose bush dimensions
vectra b outer rose bush outer diameter
vectra c rear rose bushes
