Results 1 to 10 of 11
Thread: z20net boost control valve sensor
    Regular Member dj1's Avatar
    leek
    Default z20net boost control valve sensor
    hi, i had trouble with loss of turbo boost,warning light came on. i got the fault read came back boost control valve sensor, i got the part no. off the original 12787706 and replaced it. did'nt work then read on here there was another simular valve under the plastic cover so i put the original valve back and replaced the the 1 under the plastic cover with the new 1!!! so now i have 2 valve/sensors part no 12787706 fitted and the car runs like a dream!! i'm confused!!!!
    i've since read the part nearest the turbo should have been part no 55354158 and part no 12787706 under the plastic cover but mine were the other way around
    can anybody please confirm!!!! thanks
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Quote Originally Posted by dj1 View Post
    this is the correct way round, mine is this way and is working perfectly
    South east
    Quote Originally Posted by Caveman_nige View Post
    Have a read of Jezzy's Z20NET specification sheet (a sticky thread in the petrol engine-tuning section) and it mentions the boost valve near the turbo as being 55354158, and then Deztroyer's update in that thread mentions the second valve, near the ECU, being 12787706.
    Jul 2011
    peterborough
    ive got this sensor in both locations 55354158 , keep getting faults but think its something else do we no the name of this sensor 12787706
    Jun 2009
    South Coast
    They are both called charge air boost valves, not very expensive
    South east
    Quote Originally Posted by kirby View Post
    So you've got the wrong sensor in one of the locations, but you think the fault lies elsewhere...?
    Jul 2011
    peterborough
    Quote Originally Posted by Rebellion View Post
    yeah i no , well i will try to get the other number 1 then , but fault poss lies with afm as thats the code 0102 , but i changed this first 6/8 months ago & just keeps coming back,also done both lambdas as 1 was broken but didnt bring up fault, the boost controllers ( although 1 could be the wrong 1)
    well quick google & copy & paste brought this up so yep they are different off to dealers monday
    Charged air bypass valve part no 55354158
    Turbocharger Wastegate Actuator Vacuum Control part no 12787706
    Jul 2011
    peterborough
    well put the new sensor in 7706 & fitted it , took for little drive & up pops eml light fault still the same i been chasing for 6 months 0102,
    changed afm (fuel parts)6months ago when this 1st occured least now got 2 different sensors ,
    only thing i could see different apart from numbers is on the metal pipe end of the sensor the 7706 has a bigger internal diameter,
    so with this in mind should it be nearer to the wastegate actuator rather than being on the inlet manifold & just being an air bypass valve ie what 4158 is labelled as but this part is fitted at the actuator end,
    mine is now like caveman nige in post 2
    also dj1 have u now got fitted 2 7706 valves fitted
    Jun 2009
    South Coast
    that error code tends to be MAF related. try taking it off and blowing through it with a can of air duster or even an evaporating cleaning spray like carb cleaner. Clear your codes, if you don't have a gadget for this then disconnect your battery for half hour..
    Jul 2011
    peterborough
    appreciated but done this before & comes back is this just as it gets dusted up or could it be a bad 1 & worth getting a genuine one, think got quoted bout £140,
  1. Z20NET Boost Control Valves - POLL
    By Rebellion in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2012, 21:39
  2. 1.9 Boost Sensor and EGR Valve clean
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2011, 16:16
  3. Boost sensor & EGR valve
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2011, 11:25
  4. Turbo Boost Control Valve?
    By stupottyuk in forum Engine & Drivetrain
    Last Post: 20th July 2010, 12:59
  5. EGR VALVE and BOOST SENSOR cleaned today!
    By VXR CDTi in forum Engine & Drivetrain
    Last Post: 11th November 2008, 23:20
z20net boost sensor
z20net boost valve
how to test boost control valve vectra
egr valve z20net
blow off valve z20net
boost valve
opel vectra c bypass venttiili z20net
opel vecta c bybass venttiili z20net
signum z20net boost valve testing
