Thread: can the egr be deleted Z30DT
    Regular Member rayvo-gsi's Avatar
    warrington
    Default can the egr be deleted Z30DT
    As above is this possible as iv got a guy coming on wednesday to remap my car and hes only 85% sure he can do it.Any feedback would be great
    Jan 2012
    Lancs
    Vehicle : Signum Design 1.9cdti
    Default egr mapped out
    Quote Originally Posted by rayvo-gsi View Post
    I've got a 1.9cdti Z19dth, mines blanked and mapped out of the car, same with my dpf. MAS performance did it for me.
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    I have spoken to a few remappers, the EGR can be coded out.
    Be very careful on who and how they remap the car, if all they want to do is raise fuel pressure then be wary. One of the differences betwee the Y30 and Z30 is that the turbo has an electronic actuator as opposed to a vacuum operated one so it should be possible to increase boost.
    When you car does a DPF regen it increases injector timing to esentially over fuel the car, if a modest change in injector timing was made, along side a slight increase in fuel pressure and boost then you could be onto a winner.
    I live remap would be the best way to go, that way alot of the different parameters can be chaged/tested.
    Make sure that the guy remapping your car just doesn't turn off the EGR as this will still throw up the EML.
    warrington
    Quote Originally Posted by lee_umney View Post
    Thanks for the info Lee will let you know how i get on
    warrington
    I got in contact with the guy whos doing the remap and asked him what would be changed he replied
    the following is changed
    Torque rail turbo injection boost air and drive ability
    Sep 2010
    6 Post(s)
    Trim : SRI
    How did it go?
    Who did the remap?
    Hows it feel/drive?
    warrington
    How did it go?
    Who did the remap?
    Hows it feel/drive?
    Im gutted he never turned up i went to a few places yesterday and they all said that the ecu has to be removed from the car and sent off for remap.So i think he realised he couldnt do it and just never bothered showing up.
    warrington
    Lee iv noticed you have the same car as me do you know how many live wires are on the egr iv got 5 but only 2 are showing live.
    Sep 2010
    6 Post(s)
    Trim : SRI
    From the 5 wires attached to the EGR, according to the wiring diagram they are as follow:
    Pin 1 - 5 Volt Reference
    Pin 2 - Sensor Low Reference
    Pin 3 - EGR Recirculation Valve Sensor Signal
    Pin 4 - EGR Recirculation Valve Motor High Signal
    Pin 5 - EGR Recirculation Valve Motor Low Signal
    Not sure how much this will help you.
    warrington
    Cheers Lee i did another test with it plugged in and engine running and got 4 live wires and 1 earth so i guess the egr is goosed.Its unplugged at the minute but drives better than it ever did i can live with the EML lol
  1. Can the egr function be deleted from the ecu?????.
    By felixx in forum Diesel Engine related
    Last Post: 26th February 2011, 18:56
5 volt wire on ecm vectra 3.0 cdti
z30dt egr delete
