Thread: best place for re-map
    Apr 2012
    hampshire
    Default best place for re-map
    hi there, after owning the vectra for 2 months think is time for a re-map, turbo kicks in about 3rmp n runs out about 4ish rmp.
    hoping with the re-map i can get the turbo to kick in bit early n better responce.
    any directions where to go/do?
    cheers rick
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    the 2.2 your very limited for options. i had a dti and struggled to find anything that will map it but eds will map it. have a look on regal autosport
    morecambe
    28 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    things have changed aklot the 2.2dti is easy to map so is the 2.0dti its only a bosch unit after all so there you go also its doable through odb
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    EDS do a map for the 2.2 DTi but they're not that easy to map due to the hybrid ECU setup. A lot of companies assume it can be done because they've done a Vec B DTi but the setups are not the same. Best ring some companies and ask if they've specifically done a Vec C DTi.
  1. Best place to buy a CAT
    By Bloicy in forum Vectra C / Signum Car Chat
    Last Post: 30th November 2011, 23:04
  2. What a place
    By paddyvectra in forum The 'Off Topic' room
    Last Post: 24th November 2011, 14:18
  3. I think this is the right place to ask?
    By curtis in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2007, 09:45
  4. best place for meg x
    By Eddie Dee in forum Detailing and Car Care Discussion
    Last Post: 18th March 2007, 11:28
  5. best place to look
    By blackbeauty in forum General Chat
    Last Post: 11th February 2007, 00:02
