Thread: p242f (p/filter diff pressure sendor malfunction)
    Regular Member lutonmatt's Avatar
    Feb 2012
    kent
    Default p242f (p/filter diff pressure sendor malfunction)
    keep getting this code come up on mine and it puts it into limp home mode
    i thought it was a split inter cooler hose but changed that and its still the same
    what could it be is it the filter/cat or is it the sensor thats on the bulkhead
    pluged it in while i was at work today and it says the filter is 53% full
    is a 08 vectra 1.9 150
    Regular Member carl78's Avatar
    Mar 2012
    Telford
    Hiya try the senser on bulkhead also check pipe down from senser to the dpf i had same thing happen to mine
    Feb 2012
    kent
    checked all the pipe work it looks ok
    Mar 2012
    Telford
    Mine did the rubber pipe on top of dpf till it snapped so got a new one.I had the dp senser changed still had it going into limp mode and dpf was 58% full and could'nt do forced rejen on it so in end gutted dpf and deleted from ecu fine ever since hope you get to the bottom of it
    Feb 2012
    kent
    i got to see a customer of mine who is a vaxuhall master tech but cant find his number lol
    but i am hoping its a sensor or just clean the dpf as i dont have the money for a new one at the min
    and how do you delete them from teh ecu can a tech 2 do it
    Mar 2012
    Telford
    Well i had 3 dpf's in 3 weeks and got p**d off with it gutted dpf then had no limp mode and no spannerlight but had it remapped 2 delete dpf and egr but not sure about tec2
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Make sure you have the latest ecu software in
    Feb 2012
    kent
    i was thinking about ringing vauxhalls anyway to see if there is any recalls on the car
    was going to do it earlyer but been busy doing mots all day might ring them tomorrow
    Feb 2012
    kent
    well being a vauxhal and they do as they please
    yesterday it did not loose any power or anything
    today it did but did not fault until a lot lot normal then last week
    might take the laptop into work tomorrow and regen the cat
    was going to do it saturday but as it did not faulter i did not want to touch it
    Feb 2012
    kent
    well changed the boost sensor today and regened the cat
    after it showed it to still be at 70% but will look tomorrow
    was no faults on teh way home but very rare that there is
    went for a drive yesterday took ages for the fault to apper but when it did i deleted teh code and it kept coming back every few mins
  1. Replies: 26
    Last Post: 14th March 2014, 01:03
  2. P242F Error Codes
    By Godzilla in forum Diesel Engine related
    Last Post: 24th May 2010, 23:05
  3. Particulate filter pressure sensor?
    By Turbo Gav in forum Engine & Drivetrain
    Last Post: 24th April 2009, 09:54
  4. diff
    By g4rtk in forum Handling & Braking
    Last Post: 29th June 2007, 21:13
