Thread: Torx screws!
    Regular Member larrysSRI's Avatar
    Nov 2009
    south wales
    Default Torx screws!
    I am attempting to take my back bumper off to fit parking sensors and every Torx trim screw is rusty and useless. Stuck now as can't get the two out by the number plate!
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    16 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    have you tried to insert the next size up?..hammer it in if need be..
    Regular Member coldo's Avatar
    Scotland
    Quote Originally Posted by nikroc View Post
    +1
    Sock them in wd40 first also if they are all rusty... helps penatrate the thread so easier to turn...
    Feb 2011
    Selby
    You may also be able to hammer a straight bladed screwdriver in. Worn Torx drivers can also make the problem worse. I found the cheap ones I got the market had a habit of riding up and damaging the screw head. Got a decent set from Machine Mart and they fit beautifully now.
    It really is worth giving any bolts/screws that are exposed to the elements a blast of PlusGas and leaving them 15 minutes to soak in, then try tightening them slightly to break the corrosion, before trying to undo them.
  1. Torx screws on coil pack.
    By ridgers84 in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2012, 22:19
  2. Torx screws in wheel arches !
    By monkeez in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2011, 21:53
  3. Rusty Torx Bolts & Screws
    By Hedgehog70 in forum Vectra C / Signum Car Chat
    Last Post: 13th June 2009, 11:27
