Results 1 to 10 of 19
Thread: Irmy Grille.
    Regular Member Gazza90000's Avatar
    Newcastle upon Toon
    Default Irmy Grille.
    Awaiting Delivery but can't find any how to's ...
    Is it easy Any one have pics ? Where are the pins or nuts keeping the grille in.
    As you can guess this is all new to me...
    Regular Member Brocks's Avatar
    Feb 2006
    Wirral
    8 screws of the old grille. Put the new one in and eight nuts later...job done. I did it in a hospital carpark in the dark in 10 minutes!
    all you'll need is a pozidrive screwdriver and an 8mm socket, and you're home and dry.. i can do one in under 2 mins now..and that includes unlocking the car..
    drilldrivers.. don't you just love them..
    [Ex]Admin Duncan's Avatar
    Dead easy. Pop the bonnet and on the back of the Vx grille you'll see a number of screws that you unscrew.
    The Irmscher grille has threaded posts on it which nuts are tightened on to attach the grille.
    Just be careful you don't drop any into the engine bay when you're doing this!
    Here, there and every where!
    Pre facelift is easy. Open bonnet, remove 8x screws, remove grille. Fit Irmy grille, fit the supplied washers and 8mm nuts to the studs. Close bonnet. Take pics
    Job done.
    Facelift is totally different as the front bumper has to be removed.
    Hey, how good is that?! Four replies inside 10 minutes!
    we're on form tonight
    You found them yet D
    Regular Member RSV_Ecosse's Avatar
    Falkirk, Scotland
    Takes all of 5 mins to fully remove and refit from start to finish.
    Must be one of the easiest styling mods ever and makes such a difference to the look of the front end of the car!!!.
    Newcastle upon Toon
    Quote Originally Posted by Brocks View Post
    Sounds painful....
    Everyone else thanks folks. Looking forward to Saturday..
    Grille , Chrome Number Plate surround and new Number Plates to go on with the subtitle www.vectra-c.com
    Just plucking up the courage to put siggy fog light surrounds . Reading on the forum you need to remove the bumper
    I may ask for help on this too...
  1. Replies: 19
    Last Post: 18th October 2008, 14:35
  2. irmy grille......
    By bobbyboy in forum Vectra C / Signum Car Chat
    Last Post: 7th June 2006, 12:37
