Results 1 to 2 of 2
Thread: Oil pressure warning light 1.9 cdti 150
    southampton
    Default Oil pressure warning light 1.9 cdti 150
    Hi all,
    When i turn my ignition on i get an oil pressure warning light up which goes off once i start the engine, only to come back when i switch off.
    When it first happened i gave it an oil changed which made no difference. I thought maybe sensor but it goes when engine is running so i am now thinking split hose. Its a 1.9cdti 150, what do you guys think.
    Sounds quite normal to me, especially if you have been using GM-LL specification oil
    If I switch mine off it takes about 2 seconds then the oil light comes on, but sometimes it can be almost immediate
    Restart the engine and it goes out
    I would be more concerned if it was blinking, flashing, or on whilst the engine was running
    If it is blinking or flashing, then this suggest the sensor has reached the end of its life, but will last about 1000 miles before failing
    Equally, I would very much doubt a split hose would cause this as both sensors take their readings from the internal pressure of the engine
  1. Tyre pressure warning light
    By jodiexii in forum Electrical & ICE (including SatNav)
    Last Post: 21st June 2012, 06:46
  2. Tyre pressure warning light
    By jodiexii in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2012, 21:22
  3. emissions warning light cdti sri150
    By chrisknights in forum Engine & Drivetrain
    Last Post: 10th May 2011, 18:00
  4. Oil pressure warning light
    By shadders in forum Vectra C / Signum Troubleshooting
    Last Post: 5th January 2011, 17:18
  5. Low oil pressure warning light
    By volvo12345 in forum Engine & Drivetrain
    Last Post: 6th January 2008, 18:57
Opel 1.9 cdti oil warning
vauxhall vectra c oil pressure light
low oil pressure insignia cdti
https:www.vectra-c.comforumshowthread.php161997-Oil-pressure-warning-light-1-9-cdti-150
vectra c oil switch cdti
vectra c 1.9 low oil pressure
vauxhall vectra 1.9 cdti oil lite
vectra 1.9 cdti oil pressure
Where is oil pressure switch on vectra 19cdti
vauxhall vectra oil pressure light
vauxhall vectra cdti 150 oil light
opel 1.9cdti oil pressure
vectra 1.9 cdti oil pressure light
vectra 1.9 oil pressure light
vauxhall vectra 1.9 cdti sri 150 oil warning light
2008 vectra 1.9 cdti warning lights
location of a oil pressure sensor vectra 1.9cdti
