Thread: Rear rec unit and tow bar electrics
    Apr 2012
    falkirk
    Default Rear rec unit and tow bar electrics
    Hi can anybody tell me the answer to this problem just spent £700 quid to get a new rec unit fitted at dealer I have a caravan to which the electrics worked ok prior to getting this fitted having just tested the electrics the stop lamps don't work on the caravan I,m a little disgruntled the car is fitted with a can bus 7 way relay bypass system I,m ready to scream as I,m booked to go on holiday on Friday can anyone help plz
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Quote Originally Posted by alex m View Post
    The unit needs to be programmed and told it has trailer electrics fitted I believe... Could be wrong but in Vauxcom I am sure I have seen a program option in the REC to make the tow electrics present or not present.
    Apr 2012
    falkirk
    All other lamps work ok so could this possibly be reason thinking about taking it back to dealer tommorrow morning
    Middlesex
    Trim : SRI
    Mileage : 100k
    ABSOLUTLY mate - if it worked with the old REC and not the new- suggests its not been programmed with all the functions your old one had..
    Take it back - get someone out with a TechII and say you will wait while they re-programe.
    Apr 2012
    falkirk
    Cheers mate will do thanks for your help
  1. Rear Electrics
    By steve in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2011, 16:27
  2. Rear door electrics
    By John2360 in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2011, 23:13
  3. rear electrics
    By scottyd in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2009, 18:45
  4. Started fitting my rear electrics today
    By Ian-Highlander in forum Electrical & ICE (including SatNav)
    Last Post: 27th July 2008, 20:55
  5. rear electrics? what am i doing wrong?
    By blue estate in forum Electrical & ICE (including SatNav)
    Last Post: 3rd July 2008, 20:47
whats the rec unit on vectra
vectra c rec towbar
