Results 1 to 10 of 23
Thread: Safeguard Check!
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Default Safeguard Check!
    Hi Chaps,
    Ok - so fitted a CDC40 Opera with full screen etc into my 2006 Estate today - and all was fine etc
    But now I get a 'Safeguard Check' when I turn the ign on... Guess this is because the screen before didnt have the check system etc..
    So - after a search - I thought rear quarter windows and I need to join the two spade connections together on each side - so this is what I did:
    BUT - I still get the 'Safeguard Check' when I turn the ign on - so maybe this wasnt the issue...???
    Ive checked the fuses in the rear fusebox and all seem fine..
    So - HELP chaps as that warning is going to get on my nearves
    Ant
    Engine : 1.9 CDTi
    If you have Tech2 or the like you can read the ecu and find out the problem
    Middlesex
    Trim : SRI
    Mileage : 100k
    OK - so I have Vauxcom...
    No DTC's that point to any issue...
    Anything specific I can / should look for and where in Vauxcom?
    Middlesex
    Trim : SRI
    Mileage : 100k
    OK - SORTED!!!
    I'd joined the wires - and as I was doing one window at a time I tested it by turning on the ign.. Once I had done both still the same message..
    BUT - what I DIDNT do was lock/arm the car and then unlock whilst testing it...
    Now I have actually locked and armed the car - going back to the car and unlocking and turning on ign - no more error!!!
    So lesson learned - you NEED to arm / disarm the car to test this - not just turn the ign on / off...
    Regular Member stevothelegend's Avatar
    Jul 2012
    Sherburn, Durham
    whats the procedure for arming then disarming ? i cant understand the owners manual - cant get to grasps with the way its worded. im getting "SAFEGUARD" - put opcom on and got: u2103-00
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by stevothelegend View Post
    Lock it, leave it a minute then unlock.
    Jul 2012
    Sherburn, Durham
    shud the red LED always be flashing when the cars locked ?
    ive got 2x vec c's and ive never seen that LED flash once on either until yesterday when 1x car was showing "safeguard" and alarm was going off randomly.
    checked the connectors for rear quarter windows and boot lid, all seem secure.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    As far as I know yes. Mine's always flashed when the car is locked and alarmed. Never had any check safeguard messages before.
    Nov 2009
    Warwickshire
    Quote Originally Posted by AntSSSS View Post
    OK - SORTED!!!
    Really helpful info there. Good advice - thanks.
    Jul 2012
    Sherburn, Durham
    ive got 1x 06 19cdti 150 hatch and 1x 08 19cdti 150 estate and that LED has never been on on either up until like i say yesterday on the 08 plate.
  1. Safeguard Check.
    By Saxman in forum Electrical & ICE (including SatNav)
    Last Post: 3rd July 2012, 17:43
  2. Check Safeguard
    By Tam80 in forum Engine & Drivetrain
    Last Post: 24th April 2011, 08:43
  3. Check Safeguard
    By DaveG in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2011, 22:51
  4. Check Safeguard
    By BaileySRI in forum Electrical & ICE (including SatNav)
    Last Post: 1st March 2010, 22:41
  5. Check Safeguard (Again)
    By stevem in forum Vectra C / Signum Troubleshooting
    Last Post: 6th August 2008, 19:31
