Thread: Car with spanner light :-(
    Apr 2012
    Burntwood
    Default Car with spanner light :-(
    Hi , I'm hopping someone can help , I'm not mechanical minded at all so bare with me , I have a signum 2.2 design direct petrol , about once a week it breaks down :-( I get the car with the spanner and also the picture of the engine , It can take anything between 5 mins to an hour to get going again . It starts but as soon as you try to drive itcuts out and the spanner light is back , I have had it on 3 different diagnostics at a cost of about £100 so far , first time there was no code stored , next it was p1118 but the garage said he wasn't sure that was a legitimate code and said to take it to vauxhall ??? Lastly the garage were reluctant to tell me the code but said it had 2 , swirl pot and fuel pressure . He said it's more likely to be fuel pressure but it could be anything from the fuel pump to fuel rail or even a broken wire , it's a process of elimination . I can't afford to keep replacing parts that may be absolutely fine . Can anyone please give me some advice . The car drives perfect but it's so frustrating when the fault occurs . Thanks
    morecambe
    34 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    It's either the fuel pressure reg or the High pressure fuel pump mate massive weak spot on that engine changed mine not so long ago
    morecambe
    34 Post(s)
    Vehicle : vectra
    Trim : vxr
    Also the pressure reg is under a recall at Vauxhall mate
    Apr 2012
    Burntwood
    I had a recall from vauxhall for the handbrake but haven't heard from them regarding regulator , I'll ring them tomorrow .
    So you reckon just change the fuel pump ? I have found one from a breakers for £40 my concern is do they all break ? Oh there's only one fuel pump isn't there ? Underneath at back of car ?
    I'm just finding my way lol
    By Shadrack in forum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
