Thread: Fuel filter pliers
    Aug 2010
    Leeds
    Default Fuel filter pliers
    Can you please show me a link to the fuel filter pliers to buy for the 1.9 cdti filters?
    Im not interested in other ways of removing it.!!
    Regular Member tangoman's Avatar
    Berinsfield,Oxford
    Vehicle : VXR Estate
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    Admin plasma's Avatar
    On the Forum
    309 Post(s)
    Engine : 150
    Mileage : 74000
    http://www.ebay.co.uk/itm/1807715290...84.m1439.l2649
    I've bought the above, they work fine..
    or are you looking for the tool to remove the ring around the top of the fuel filter housing to open it?
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    If you mean removing the top from the filter housing you have a few choices..
    the 'proper' tool as seen here:
    Or oil filter pliers like this:
    I have both and like the 'proper' tool as it allows you to torque to the correct setting..
    BUT if you mean pliers to remove the fuel lines - as others have listed above as I just use two small flat blade screwdrivers.
    HTH
    Regular Member lutonmatt's Avatar
    Feb 2012
    kent
    http://www.ebay.co.uk/itm/BRAND-NEW-...item2a19f876c2
    much cheaper then the rest use the red pair is what i use all the time
    and the cap pair of water pump pliers or if your feeling strong can do it by hand
    Engine : 1.9 CDTi
    I use a fuel sender toop to remove the lid: http://www.ebay.co.uk/itm/FUEL-SENDE...item2a15a8a046
    But the link by Matt will do the job for a diy mechanic but they do bend after sustained useage.
    Aug 2010
    Leeds
    It's the tool for the fuel filter pipes i want and plenty of choice above links thanks lads.
    I have a nice pair of Blue Point water pump pliers to remove the filter and a vice to get it off.
    Don't want to break the filter flow/return pipe clips!!
    On the Forum
    309 Post(s)
    Engine : 150
    Mileage : 74000
    Quote Originally Posted by lutonmatt View Post
    I bought a set of these as well lol..
    Feb 2012
    kent
    i have had my set for years and am a mechanic so use them a fair bit
    but i always try and press them in with my fingers to start with
    if i can get them all off saves a walk to my tool box lol
  1. Replies: 19
    Last Post: 30th May 2012, 15:53
  2. fuel filter
    By strothrc in forum Engine & Drivetrain
    Last Post: 14th March 2012, 23:15
  3. How do i remove the fuel lines from 3.2 fuel filter...?
    By killer_bunny in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2010, 23:07
  4. Fuel Filter
    By nikroc in forum Engine & Drivetrain
    Last Post: 23rd March 2008, 23:11
  5. Oil Filter location and Fuel Filter
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2006, 10:31
