Results 1 to 10 of 17
Thread: scrap inlet manifold
    Regular Member wildchild's Avatar
    Sep 2011
    west-mids
    Vehicle : vectra c
    Trim : elite
    Engine : 1.9 cdti 16v 150
    Year : 06
    Mileage : 111250
    Default scrap inlet manifold
    this is a strange one i know but has anyone got an old/scrap inlet manifold z19dth that they have replaced and are getting rid of the old one free would be brill but if you want anything for it n i cover postage its for an experiment that will be covered with an how2 and hopefully end the problems we all have with them thanks in advance
    gaz
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    the dealers kept mine last year when they put a new one on sorry
    Sep 2011
    west-mids
    Vehicle : vectra c
    Trim : elite
    Year : 06
    Mileage : 111250
    Cheers buddy no probs anybody else as this would hopefully benefit everyone as a longterm but cheaper alternative to buying a brand new 'revised' one which seem to be failing at the moment thanks
    gaz
    Sep 2011
    west-mids
    Vehicle : vectra c
    Trim : elite
    Year : 06
    Mileage : 111250
    bump.
    Regular Member Dane-10's Avatar
    Feb 2012
    Sheffield
    I may have one, but i split it in half to take a look at it (still got the bolts to put it back together)
    The valves are screwed well and truly though.
    There is my thread here with some pictures........
    http://www.vectra-c.com/forum/showthread.php?t=160850
    PM Me if of any use, Can have it.
    West
    Harvey Smith swapped his manifold over, then modified the old one by removing the butterflies & plugging all the holes & alloy welding it all back up to seal it & then refit it... there's a thread on here.
    The fault with the old & new manifold is simply the build up of crud caused by the egr design as with any diesel derived motor... adding a catch tank can slow the process but ultimately blanking / removal of egr will cure the fault full stop.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    The easiest way to get the flaps out is to chop the top swirls off with a chisel, Then use the chisel to hit the inside flaps & bend then inwards so they collapse 'v' shape then they will come out, the bottom actuator motor arm is tricky & maybe better left in as any hammering will break the surrounding cast, as you can tell i had a play with my old one & i think i binned it but not sure, To be honest after changing a few (& doing the how 2) id just replace it.
    Oct 2010
    Darlington
    I am sorry but I do not have a spare inlet manifold at present. The new one was modified and put on the current engine. The old one was then refurbished and modified. This is going on another engine which I am well on with build. The new engine, with some interesting mods, conventional single mass flywheel and uprated clutch will all then be fitted, all at the same time.
    At that point I will have a fully working proven engine for sale complete with all ancilliaries plus transmission parts.
    South Central England
    10 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    The local dealers may well have some in the bin. They get returned if it is warrenty work but otherwise they just go in the bin. Got a couple of actuators that way and an EGR valve which works fine when cleaned.
    Sep 2011
    west-mids
    Vehicle : vectra c
    Trim : elite
    Year : 06
    Mileage : 111250
    thanks for all the replys lads dane-10 said i could have his old one cheers once again
    gaz
  1. inlet manifold
    By chay6684 in forum East Scotland
    Last Post: 11th March 2012, 23:10
  2. inlet manifold
    By chay6684 in forum Engine & Drivetrain
    Last Post: 10th January 2012, 23:24
  3. inlet manifold
    By vectra66 in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2011, 08:10
  4. New inlet manifold,,,,new car !!!!
    By collyb in forum Engine & Drivetrain
    Last Post: 15th April 2011, 13:10
  5. cant get my inlet manifold off!!!
    By Curly7 in forum Engine & Drivetrain
    Last Post: 14th August 2008, 18:14
