Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: My washer bottle has no sensor!!
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Default My washer bottle has no sensor!!
    My 2006 Life doesnt seem to have a sensor on the washer bottle...
    Installed a CDC40 today and it keeps telling me the washer fluid is low.. We had a look and no sensor on the washer bottle..
    thats annoying!
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    If the plug's there just fit one, they're only a few quid to buy. Even if the plugs not there it only earths pin 14 (I think it's that pin but double check before you do this) under the UEC out so a wire run from there to the sensor and from the other side of the sensor to earth does the same job
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by Ian-Highlander View Post
    Plugs are there OK - just need the bottle with sensor then!..
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    No, just the sensor and the grommet for it, drill a hole in your current bottle.
    Regular Member coldo's Avatar
    Scotland
    When I upgraded to my GID screen I found out the washer bottle didnt have the sensor either. When I fitted one I then discovered the wiring plug head (already there taped up by the light loom) was bady caroded...
    I ended up cutting the head off and joining the wires then sealing the full thing back up... In effect telling the car the cuircuit was complete which has stopped the fluid sensor ever comming back on!
    Middlesex
    Trim : SRI
    Mileage : 100k
    Ahh I see - so just drill near the bottom and fit - job done!
    Scotland
    Make sure and take the bottle out to do this. It can be done in place (I did this) but it was a complete ****** to do!
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Here ya go, this is when I did mine on my old saloon. http://www.vectra-c.com/forum/showthread.php?t=107076
    Scotland
    There is a space for the sensor to be fitted at the back of the bottle across from where the pump is located... You will see it it you take the bottle out or get right under the car to look at it...
    Make sure and not do the same as me and forget you need to drain the bottle first... lol... I got a bit of a supprise...!
    Aug 2010
    Leeds
    Why do you need a electronic gizmo to tell you to put some water in?
    It's one of your weekly checks oil water and screen wash & brake fluid.
    It's not rocket science it's just a Vectra.
  1. For Sale: Windscreen Washer Bottle Sensor
    By MrDerv in forum Parts for sale
    Last Post: 1st March 2012, 23:30
  2. For Sale: Washer Bottle Level Sensor
    By Das in forum Parts for sale
    Last Post: 26th August 2011, 14:14
  3. washer bottle sensor
    By paulvectrac in forum Styling
    Last Post: 17th September 2010, 19:50
  4. Washer bottle Sensor Position
    By redraptor_141 in forum Electrical & ICE (including SatNav)
    Last Post: 29th May 2009, 08:05
  5. washer bottle sensor
    By kpf1grandprix in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2008, 23:28
