Results 1 to 10 of 26
Thread: It's looking like my car's got to go.
    Regular Member badback's Avatar
    Runcorn
    Default It's looking like my car's got to go.
    Rather cheesed off about my car at the moment, the bonnet is desperate for a respray and a spring has snapped, they are the least of my worries though. My Auto gearbox is playing up it'll go into reverse perfectly to get out of the garage, but when I select Drive it waits 2 or 3 seconds then jolts into gear. It seems fine once it's warmed up, no problem selecting Drive, but I've read a few threads on here and it seems it's only going to get worse. So I'm thinking of putting it back to standard and getting rid, rather than spending a daft amount of money sorting the gearbox. Gutted tbh, loved the car since I've had it, and would have kept it for a few years longer. Not sure what to replace it with though, totally lost interest in cars this last few weeks, hence not being on here much.
    Regular Member wildchild's Avatar
    Sep 2011
    west-mids
    Vehicle : vectra c
    Trim : elite
    Engine : 1.9 cdti 16v 150
    Year : 06
    Mileage : 111250
    hi buddy. its going to be a daft question but can you/have you check/ed the oil level in the box that sounds like when older gearboxes used to hesitate when low on oil but i dont know whether newer boxes suffer from this. HTH
    gaz
    Runcorn
    Not sure how to check it mate, my backs fubarred so I can't do much on the car myself. I was going to ask a mechanic to flush it and put new fluid in, but after reading a thread with exactly the same symptoms as mine I lost interest as it was around 2k to fix it.
    They normally only die if the oil is contaminated so new fluid can't do any harm. If it doesn't fix it then maybe its time to shift it on.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    hey buddy where you been? i would try a flush thru with new oil and see if that helps fella but you cant get rid untill you try the obvious 1st fella
    Sodding Typical on Sea
    Hi Col,
    Long time no speak mate,
    Don't give up on the gearbox, I suspect the fluid needs a flush and new filter as the thickness of the fluid in the valve casing until it warms and thins is exactly what I read from your descriptions, used to be rife in the BMW 7 series boxes.
    Runcorn
    Thanks guys, I'll give my tame mechanic a bell and see if a flush and new fluid sorts it, I'd rather keep the car, just a bit cheesed off with it at the moment and lacking enthusiasm.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Defo oil flush and fill mate.. the auto boxes have to be trained and filled approx three times too I believe as the oil stays in the torque converter..
    Made all the difference on my father-in-laws auto box (not VX but same technology) ...
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Try the oil change as others have said mine got changed for the same symptoms however there can be a number of causes for the same symptoms, mine was terminal doesn't mean they all are
    Oct 2011
    Essex
    Autobox specailist are often cheaper to deal with too....
  1. What car's will these wheels fit? **HELP**
    By Vaux-Man-G in forum General Chat
    Last Post: 11th December 2008, 15:45
  2. My car's been upgraded ?
    By craigmerry in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2008, 08:21
  3. Any one know what a car's 710 is?
    By Brocks in forum Comedy & Humour
    Last Post: 3rd January 2008, 16:05
  4. Our car's at PVS
    By Jay Kay 313 in forum 2007
    Last Post: 28th June 2007, 20:00
  5. Car's in for it's MOT
    By AJA in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2007, 01:13
