Thread: 2004 1.8 Vectra Service
    Regular Member coldo's Avatar
    Scotland
    Default 2004 1.8 Vectra Service
    Im planning on doing a full service on both my Vectra's in the comming weeks...
    Both are Z18XE with one doing 61k and the other 89k.
    From research I have worked out I should do the following..
    Pollen Filter
    Air Filter
    Fuel Filter
    Spark Plugs
    Oil Filter and new oil
    Fluid top up of breaks and coolant (if needed)
    Is there anything to be added to that list (belts wise, both have had timing belts changed in the past 2 years and within 20k miles)
    I found this kit on ebay which looked like good price...?
    http://www.ebay.co.uk/sch/Vehicle-Pa....8+service+kit
    Pollen filters are cheap on ebay also... (but is this one any good..?)
    http://www.ebay.co.uk/itm/Vauxhall-V...item33668ec715
    So that leaves the oil and the sump plug copper washer... Where is the best places to get these from... and what ones (oil grade etc) should i get for this engine?
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    The oil should be 5/30.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 135000
    when you changed the cambelt did you do the water pump as well on both?
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Id be looking at a coolant flush and fill - and also a brake fluid change if not been done in 2 years...
    Scotland
    not sure on the new vectra for the water pump... i had it done on mine however.
    The power steering is making a whine and a quick check shows the fluid is below the dip stick level so will need to top that up as well.
    Can do the coolant but how do you do the breaks (possibly one for the mechanic...!)
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    you can pick up a good proper sump plug and copper washer from halfrauds, then you can use a proper socket on it..
    Middlesex
    Trim : SRI
    Mileage : 100k
    Use an Eezibleed for the brakes - if your not sure - best to get someone to show you first time as you dont want to muck about with brakes if your not 100% sure..
    A
    Scotland
    Random other thing....
    The boot bumps stops... One of them had broken and freely twists in the socket resulting in the boot lid moving...
    So need to order a new one... Will try the scrapys but does anyone have the vauxhall part number should I decide to order one?
    PRESTON
    Don't forget to change the batteries in your key fobs, especially the spare one you keep in a drawer at home, often neglected and when you need it, it's flat!
  1. 2004 vectra sri 2.2 dti
    By garyvectrac in forum Quick Photo Album
    Last Post: 18th February 2013, 20:36
  2. My 2004 Vectra LS 2.0 DTI
    By bigdunk1985 in forum Quick Photo Album
    Last Post: 19th August 2011, 21:32
  3. 2004 vectra 2.2 sri
    By crap vectra in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2011, 15:07
