Thread: Help, tyre damage advice+brakes question
    Regular Member GTS's Avatar
    Oct 2010
    Poland
    Default Help, tyre damage advice+brakes question
    Hey guys!
    On monday I decided to change my wheels into summer ones finally. On right front tyre there's a kerb damage, take a look at pics. At the garage where tyres were changed I was told that it doesnt influent on my safety on road but I have some doubts. Damage is very close to the rim.
    How do you think, am I overreacting?
    Also it's high time to change front discs and pads. I was thinking of 314mm. But the question is: will they fit with 16" winter tyres and existing calipers (Elite facelift suspension)? And if not, maybe some standard size nice looking drilled ones?
    Thanks in advance for help
    Peter
    South east
    The fact that the damage is near to the wheel rim isn't an issue, as the rubber is thicker there, so that damage will occur to the tyre and not the wheel. However, in the first photo the cut looks quite deep, perhaps 6mm? If it is that deep then it's a lot, if it's perhaps 3mm then it's fine.
    Oct 2010
    Poland
    I'd say 4-5mm. Just the rubber came off, no reinforcement or other layers visible...
    How did the tyre damage occur?
    If it was supplied like that (part worn) I would have it removed and send it back or exchange for a replacement (most places won't ask for the tyre back when you send them photos of the damage)
    As above, it does look like this tyre has rim protectors, so either leave or cut the damaged material away
    On the positive side, this is on the front offside, so you can check this prior to each use of the vehicle, and it will wear out first
    On the negative side this is probably a MoT failure (if you leave the damaged material in place) and the tyre chalk markings will make it obvious to anyone closely looking at or inspecting those tyres
    11 Post(s)
    Would superglue be strong enough to stick the flap back into place?
    Yes, but would there be any benefit?
    The next issue with superglue is it would harden the rubber, a more appropriate adhesive should be used in order to retain the flexibility
    I use superglue only to cover tyre abrasions, not for any other purpose
    That way it remains on the surface and does not penetrate the rubber
    Oct 2010
    Poland
    As I mentioned before, it's a kerb damage (see also rim is scratched there). I didn't think about the MOT possibility, but I have it always in november, so with the winter tyres on And honestly I doubt if the store I got it in would exchange it because this is obvious mehcanical damage...
    @Dave: was thinking of this, better than cut it out. But I'm still not gonna be sure if nothing occurs at e.g. motoway speed.
    Any advices on break discs??????
    Regular Member tangoman's Avatar
    Berinsfield,Oxford
    Vehicle : VXR Estate
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    Can you see any part of the metal casing in the cut part. If not then should not be MOT failure.
    Oct 2010
    Poland
    Quote Originally Posted by tangoman View Post
    Nope mate, just a rubber underneath. Seems like I'll live
    Regular Member dannyjpuk's Avatar
    Jan 2010
    northumberland
    I also have this on my fronts where I have kirbed my wheels looks ok I guess is there is no wire showing
  1. Damage to Tyre
    By dc6839 in forum Suspension, Wheels & Brakes
    Last Post: 16th September 2011, 19:32
  2. New Tyre - Alloy Damage
    By Raze in forum Suspension, Wheels & Brakes
    Last Post: 25th August 2009, 13:09
  3. tyre sidewall damage
    By Finty in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2009, 22:20
  4. Another.... Tyre advice question
    By Jim Bob in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2007, 20:38
  5. Tyre damage
    By skippyroo in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2006, 13:35
