Results 1 to 3 of 3
Thread: rear spring replacement
    Apr 2012
    Leicester
    Default rear spring replacement
    Hello all,
    I am having the rear springs on my 2005 vectra 2.0 dti replaced. My mechanic attemped to change last week but the new ones I aquired were some 45 mm shorter than the old ones.
    Sent these back & now got new ones but to my dismay these are the same. The origional ones are 300 mm long & the new ones are 255mm. I'm thinking 2 suppliers cant have got it wrong si is it possable that when fitted these will work okay?
    There was a previous thread on this subject with exactly the same scenario, when fitted there was no problem and ride height remained the same. I'm thinking the only way this can occur is if the new springs are stronger & the car does not lower as much when fitted. Any advice would be gratefully appreciated as I have instructed my mechanic to fit & I'm hoping for the best
    Cheers,
    Pete.
    VOTING UKIP IN AVELEY
    18 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    yep should be ok ....
    Apr 2012
    Leicester
    Many thanks for that soul man.
  1. Front spring replacement
    By maz in forum Suspension, Wheels & Brakes
    Last Post: 11th November 2012, 01:08
  2. Irmscher Spring Replacement
    By honigstrauss in forum Suspension, Wheels & Brakes
    Last Post: 14th April 2012, 17:25
  3. spring replacement afl light now flashing
    By iceeee in forum Suspension, Wheels & Brakes
    Last Post: 24th February 2012, 18:06
  4. rear spring replacement
    By meathead in forum Suspension, Wheels & Brakes
    Last Post: 17th January 2010, 04:49
vectra rear spring replacement
