Thread: abs and t/c lights
    Jun 2011
    cumbernauld, scotland
    Default abs and t/c lights
    Can the abs/tc warning lights be turns off and if so is there any one near Glasgow that can do it
    Jim Dickson tyres can do this (may charge you though)
    They had to do this after replacing some parts on my car for me
    However how long has it been on for?
    It should reset after 20 or so miles
    If the lights have been on for some time then clearly a fault has occured and needs to be investigated, then repaired
    The usual causes are driving over variable road surfaces (such as ice), disconnecting the hub carriers (such as for front shock absorber replacement), and so on
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    Could be the plug on the abs module try cleaning it. Or its faulty. But be careful when removing the plug you can easily break the wires.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    If the abs/tc light is on permanently then there is a fault buddy and no amount of resetting will put it off.
    Chances are it'll be a dodgy connection at the wheel. If you take the wheel off you'll see that attached to the chassis leg is a round connector. The pins in there are prone to corrosion so that's a place to start. After that i'd be looking at getting the codes read as you can't really guess which wheel the fault is coming from or it may even be a faulty abs unit but this is rare.
    If the fault is fixed then the light should go off in a matter of metres not miles
    Jun 2011
    cheers guys yeah it needs a new hub for the mot but not got the money for a new one was hoping to turn the light out the same way you can with the egr one.
  1. Brighter Lights for side lights, Vectra SRI150
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2011, 23:50
  2. Replies: 2
    Last Post: 31st March 2010, 13:30
  3. Philips bluevision h7 head lights & side lights brand new
    By davidlewis24 in forum Parts for sale
    Last Post: 19th March 2009, 22:42
  4. Dark lights and Rear Lexus lights finally fitted
    By Leviathan in forum Styling
    Last Post: 29th February 2008, 22:35
