Results 1 to 10 of 20
Thread: Hid bulb fitting problem, Keeps poping out. Would the clip help?
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Default Hid bulb fitting problem, Keeps poping out. Would the clip help?
    Hi all
    To cut a long story short I have been sent a replacement HID bulb (6000k 35w H&) for my facelift 06 Vec as the first one failed from Hids-Direct.
    The replacement has a plastic base (original had metal base) which fits into the light holder. It keeps popping out and of course the alignment goes wonky which is not good.
    I have the clips that came with the kit but thought I didn't need to use them as being H7. Would they sort my problem out and if so can someone maybe post up a pic of how they are supposed to fit as its defeating me.
    I don't want to send the bulb as it costs me nearly 3 quid a time to post recorded. But if thats my only option I will do so.
    Hope there is an easy fix with the clip
    Many thanks
    EDIT : I have tried to bend the side clips within the light holder to see if it needs to be tighter etc but made no difference.
    Hanging Heaton / Batley
    18 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Don't have a pic but you need the clips... Compare it to a bulb and you'll get the idea.
    scottish region
    Clips are for pre facelift vectras should not have any hassle with facelift I had plastic ones on my vectra I think will check still have them in hut
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    If they have plastic bases on the bulbs, you'll need to replace them for metal base ones otherwise they will continue to pop out due to the plastic thickness.
    The twist-fit clips are for a pre-face.
    Facelift H7's are just a push fit into springloaded clips, plastic bases wont sit securely in them
    Engine : 1.9 CDTi
    As above.
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Thanks very much for all your replies. I did question hids direct about the base being plastic but they just shrugged it off.
    Can someone maybe link me to the correct eBay item ( replacement bulbs metal base) as when I was searching I could only find the plastic based ones. I'm giving up on hids direct for now. It's been a rocky road to say the least.
    Thank you
    Engine : 1.9 CDTi
    Better off finding a seller and asking if they have any with metal bases.
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Quote Originally Posted by lee gsi View Post
    Fair enough lee good point and will do.
    scottish region
    U want my set mate as you have done me a few favours before there metal just checked
    18 Post(s)
    Mileage : 110k
    You got a pic of the bulbs and the fittings you have?
  1. HID Bulb fitting??
    By Governor in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2011, 12:45
  2. h1 main bulb clip
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2011, 09:50
  3. Bulb Warning - Lose Fitting Bulbs?
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2010, 11:02
  4. Vectra passenger sun visor retaining clip problem
    By Ollie in forum Bodywork & Interior
    Last Post: 19th January 2010, 16:29
