Results 1 to 10 of 13
Thread: Windscreen Washers
    Oct 2011
    Aberdeen
    Default Windscreen Washers
    Just went out to fit my Insignia windscreen washers and it turns out i have heated washers fitted to the car, are they standard on the GSI?
    It was a nice suprise but was looking forward to the mist type jet spray of the Insignia jets.
    Regular Member lutonmatt's Avatar
    Feb 2012
    kent
    they will fit just you wont have teh heated side
    and dont really need them at the min
    i just got a set for mine as well
    scottish region
    Keep the heated ones for winter and use insignia ones for summer
    Oct 2011
    Aberdeen
    Quote Originally Posted by lutonmatt View Post
    Quote Originally Posted by DAVIDD88 View Post
    So i take it's just a simple case of unplugging the switches for the heated washers and jobs a good un?
    And how are the heated ones activated, do they come on with the heated rear screen like the side mirrors?
    scottish region
    Yes
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Alan, you may want to look into this as there was a recall on the early GSis and Elites as there was a fire hazard from the heated washer jets
    The recall involved disconnecting the jets but there is now a revised wiring loom/jets
    Feb 2012
    kent
    i am hoping so lol
    i will be fitting mine tomorrow night when i fit my new inercooler pipe as i found a hole in one of mine yesterday
    be 50 quid i sent on it this week lol
    pipe is about 45 quid and the jets just under a fiver
    Oct 2011
    Aberdeen
    Quote Originally Posted by John IS3 View Post
    Oh dont say that Lol,
    How would i find out if mine was re-called? it may just be safer to remove and fit the Insignia jets.
    Feb 2011
    Selby
    Open your bonnet, pull off the rubber seal at the back, and open the scuttle panel on the passenger side so you can see the pollen filter. Next to the pollen filter is a socket where the heated washer jet loom plugs in.
    If you've had the recall, you'll find either there's nothing plugged into it and there's no loom going to the jets, or there's a loom going to the jets but it's unplugged, or there's a loom going to the jets that's been cut and insulated with tape. Some dealers replaced the jets with non-heated ones, some just disabled the heaters by unplugging or cutting the cable...
    Most pre-facelifts (other than poverty spec models) have the socket, but not necessarily the heated jets. There's a how-to on fitting them.
    Regular Member tonci26's Avatar
    Apr 2011
    belgrade
    Vehicle : vectra c gts
    Engine : 1.8 petrol and lpg
    Mileage : 169000 km
    how do you know you have heated washers?
  1. windscreen washers
    By bigsteve2255 in forum Electrical & ICE (including SatNav)
    Last Post: 7th January 2011, 23:08
  2. Windscreen Washers
    By RobW in forum Vectra C / Signum Car Chat
    Last Post: 24th December 2010, 22:04
  3. Windscreen Washers.......
    By david.aka.judas in forum Bodywork & Interior
    Last Post: 16th December 2008, 23:25
  4. windscreen washers
    By woody in shetland in forum Vectra C / Signum Car Chat
    Last Post: 2nd May 2008, 19:04
  5. Windscreen washers
    By T4M in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2007, 23:33
