Thread: Power Steering Light
    Regular Member Madgunner's Avatar
    Worrying bout nothing..... Cause worryings a waste of my f***ing time!
    Question Power Steering Light
    Hi everyone need a bit of help please Have been reading thread's on this tonight bout this basically my power steering light keep's coming on & going off again but the steering dosnt seem to go heavy when it come's on . It does spend more time on though. I have read bout checking the level which i will get the car down my m8's garage asap. Doe's the level go down after time? the car's just coming up to 65k can't see no visible leak anywhere & is that really the easiest way to check it or has someone found an eaiser way? Thank's for your time on this one any help most grateful
    Sounds stange but the easiest way to check the PS fluid level is to remove the front bumper skin....
    Your pump is under the OS headlight, so take the bumper skin off and you'll have loads of access to the pump.. check the level and the unions for leakage..If the light is coming on, but not affecting the steering assistance, then the pump motor is still running okay..hopefully it's just a low level..But check all along the flexible hoses for and sign of fliud escape..
    yea will do i have just been on the phone to my m8 who's a mechanic & he's gonna look at it Tuesday, hopefully it's just the fluid level that,s what he thinks anyway.
    the max to min is only about an inch, so it's really sensitive to level changes..
    Just an update i checked the power steering level & it was down just a lttle so topped it up & checked everything no leak's that we could find anyway so then started the car up & guess what? the light still keeps coming on & going out
    You don't have to get it reset do you?
    The steering has felt the same all this time so could it be just a sensor? I think there's three altogether angle sensor, pump level sensor & not sure what the other one is. Can anyone help before i have to go down me local steeler's cheers
    That may be the way forward.. sounds like you have software issues with yours..when mine went south they cleared the fault and updated the software on my car..
    Yea nice one m8 thanks for that i did go down there today, af put me in contact with a lad who works there but he had the day off so will catch up with him later & have a word with him
    if he's AF's bloke then you're sorted..
    Yea think i am m8 popped down 2day he's gonna have a look saturday. I mentioned what you said bout the software so see what happen's
  1. Replies: 4
    Last Post: 18th August 2012, 08:58
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. Steering wheel light & loss of power steering
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2012, 14:09
  4. Steering wheel warning light , no power steering!
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 22:11
  5. PLEEEEASE HELP - traction control light/power steering light on!!!
    By holdenvectra in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2010, 23:39
