Thread: Car now starts...still got some error codes.
    Vehicle : 1.8
    Engine : Petrol
    Default Car now starts...still got some error codes.
    Hi all,
    Further to this thread...http://www.vectra-c.com/forum/showthread.php?t=161324
    I've replaced the Crankshaft Speed Sensor and the car now starts and runs fine in the short time I had to test it and all fault lights have extinguished.
    However on checking the fault codes again using the pedal trick it's still showing some codes, 1 old, 1 new and the crank fault code which I'm presuming now needs clearing.
    The codes that are now left are:
    Old code: P0170 (fuel trim malfunction <bank 1>)
    New code: P0100 (mass or volume air flow malfunction)
    And the crank code of P0335 (crankshaft position sensor 'A' circuit malfunction).
    Out of interest would the ECU not realise that the sensors been changed and should for all intents and purposes be no working correctly (genuine VX part) or is there a possibility there's another fault here, the car would not start prior to change and is now fine...is it just a case of having codes erased and seeing if anything comes back?
    As for the other two new/old codes I'm guessing they are pointing firmly at the MAF calling it a day, however before I spend yet more hard earned and lose yet more skin off my knuckles is there anything I need to be considering or looking at?
    Cars a 1.8 btw.
    Cheers.
    VIP-Member puppet's Avatar
    East Ayrshire
    8 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    I had an 0170 fault thrown up on my old 1.8LS and it turned out to be the EGR in the end. I replaced the MAF and the front Lambda sensor to no avail, and eventually cured it by taking the EGR off and giving it a really good clean with carb cleaner.
    Car was starting and running, but was pretty chuggy/rough when cold for the first few minutes.
    Might be worth trying.
    Vehicle : 1.8
    Engine : Petrol
    Cheers, something to check...need to find a pic of it location now, not really looked around this engine at all, generally can't be bothered these days, but just can't afford the prices the garage wants to possibly sort things.
    Vehicle : 1.8
    Engine : Petrol
    Hmmm a quick search suggests I may not even har one on my engine...2004 1.8 Sri, will have to look in the morning unless anyone can clarify sooner.
    East Ayrshire
    8 Post(s)
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Early z18xe engines had them, but they were phased out I believe. Your original post didn't state age so I thought it might be worth a mention.
    Vehicle : 1.8
    Engine : Petrol
    Didn't think to mention tbh, thank for taking the time though as it could have been.
    May just bite the bullet and buy a MAF, don't particulary won't to though!
  1. Error codes
    By Ziggy in forum Engine & Drivetrain
    Last Post: 17th February 2012, 14:26
  2. 3 error codes
    By Hydravox in forum Engine & Drivetrain
    Last Post: 20th April 2011, 12:14
  3. Error codes, 2.2
    By Rennie in forum Engine & Drivetrain
    Last Post: 10th April 2010, 23:21
  4. Need Some Help...Vec-B Error Codes
    By Vaux-Man-G in forum General Chat
    Last Post: 9th April 2009, 08:56
  5. Help With error CODES...!!??
    By sheiky in forum Engine & Drivetrain
    Last Post: 26th July 2007, 11:30
2004 vauxhall vectra 1.8 code p0100
