Thread: Fitting & Installation of ABS Harness & brake Help sensor sensor
    Regular Member Elahi_786's Avatar
    Oct 2010
    Bedford
    Exclamation Fitting & Installation of ABS Harness & brake Help sensor sensor
    I have had the ABS & Tracking light come on for a while due to a fault in the wires.
    The code ABS Fault & NSF Wheel speed Sensor, I have purchased this http://www.ebay.co.uk/itm/2709564341...9#ht_500wt_969
    and the modification wire to brake sensor I believe and clip as the part above is a modified one and wont just fit in. Could someone help me by providing a diagram of where this wire goes and the brake sensor / wheel speed sensor. I have tried to look for the Diagram on the net and had no luck so just need to have a look at where its going. I have had a look inside the passenger side and can see some similar looking cables but need to be sure / Would be easier to jack car up or jack and remove wheel to do this
    Nottinghamshire
    What is the part number of the item that you have bought? I can't read it on the picture and I can't see that it's quoted anywhere.
    I guess you have already checked that your car was in the right VIN number range?
    Oct 2010
    Bedford
    Thumbs up
    I did not purchase it via ebay as it was dearer but by dealership as I have a trade account will update with part numbers shortly. Dealership the part was modfied and may not fit so provided me with parts for modification. Can anyone TELL IS N/S Front (Driver side)
    Nottinghamshire
    Post the part number up and also search for it on www.opeloem.com as the diagram may enlighten as to where it fits.
    Oct 2010
    Bedford
    Hi Part Numbers are 24418887 and 24427919. I checked the cable which I believe is the abs harness which was torn & the speed sensor is wrapped around a few other wires. i am sure it is meant to be connected to wheel some how.
    I believe the parts are also wrong for my car could someone provide a diagram of where the ABS Harness should go and the speed sensor.
    Many thanks
    Nottinghamshire
    You are right about them being wrong.
    How many cables do you have under the N/S wheelarch? There's 1 if you just have the wheel speed sensor and 2 if you also have a brake pad wear sensor.
    24427919 is the cable for the brake pad wear sensor if you have it fitted - it fits into the front of the brake caliper and has nothing to do with the wheel speed sensors and therefore with your fault (there is a specific warning light for brake pad wear). There are several lengths of these cables for different models of Vectra C and this is one of them. Take a look at http://opeloem.com/vauxhall/vectra_c...ts_contd_.html.
    24418887 is described as being for the front wheel speed sensor but in the picture below it's shown on the back! I suspect it may be for the back because the front axle wheel speed sensors are built into the hubs and have a captive cable (which connects to the main wiring loom at the back of the wheelarch on earlier cars and on the suspension strut on later cars) whereas the ones on the rear axle have a wiring plug on the back of the sensors themselves. Take a look at http://opeloem.com/vauxhall/signum_2...r_harness.html
    Oct 2010
    Bedford
    Thumbs up
    I think they are wrong as well.
    I have one wire and then two little wires that out below it from a socket. Ones Blue and the other was dirty so no specific colour.
    Oct 2010
    Bedford
    Any ideas on the specific part needed?
    Full Member
    Dec 2010
    London
    Engine : Z18XER
    How do you know its the wires and not the sensor
    Nottinghamshire
    Looks like you can return both of these cables then?
    As above, are sure the damage is the cable and not the sensor itself? What is the fault code that you have?
    If the cable is damaged and it's between the back of the wheel hub and and the wiring connector under the wheel arch then you'll have to repair the cable or replace the hub because the cable goes straight into the hub and the speed sensor is built into the hub.
    If the cable is damaged is above the connector under the wheelarch then you'll have to replace that part of the wiring loom (if that's possible) or repair the cable.
  1. Parking sensor fitting.???
    By crespo in forum Vectra C / Signum Car Chat
    Last Post: 9th September 2010, 21:06
  2. Replies: 0
    Last Post: 7th October 2009, 21:41
  3. Supply and Fitting of Parking Sensor HELP
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2008, 08:36
  4. parking sensor fitting nightmare !!!!
    By Gr4eme in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2007, 23:21
  5. My Parking Sensor Installation...with Pics !
    By bennyk in forum Vectra C / Signum Car Chat
    Last Post: 9th August 2007, 16:01
Vectra C abs harness connector
vectra c abs wiring loom
vectra c abs cable plug
vauxhall vectra rear abs cable
how to fit vectra c abs sensor
vectra c abs joining wire t3x
vauxhall vectra wheel speed sensor fitting
opel vectra c abs sensor plug
front abs wire harness insignia
where are the abs sensors pn a vectra c
abs loom vectra c
vectra c abs lead connector to brake pipe
