Results 1 to 10 of 17
Thread: Cuts out
    Regular Member JaceyBoy's Avatar
    Apr 2012
    Bournemouth
    Default Cuts out
    Hi Guys,
    Newby here, just picked up an 04 Signum 2.2i, noticed that when I flour it in 2nd/3rd gear sometimes about 3000rpm it cuts out then picks up again, does anyone know what this can be?, its fine cruising, only above 3k sometimes
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 85000
    perhaps its your high pressure fuel pump not able to keep up with the demand when 3k or more
    Apr 2012
    Bournemouth
    Hmm what does that mean?
    Where did you obtain the car?
    What mileage is it currently on?
    What are the last two services? (date and mileage)
    This car should have ECO Flex service (but not necessarily used by the previous owner)
    What is the interval to next service?
    (If unsure, sit in passenger seat, do NOT insert ignition key, and press the odometer reset; this displays the mileage to next service)
    Do you have any kind of warranty?
    Apr 2012
    Bournemouth
    Mileage is just over 60,000, doesn't have full service history, in fact it only has one stamp in the book, but oil & plugs & air filter seem fairly new, I will be servicing it myself this Friday.
    Says 14,000 until next service....was private sale and no warranty, only paid £1700 for it
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Its your high pressure fuel pump mate, common fault on the 2.2 direct.
    Sent from my R800i using Tapatalk 2
    Apr 2012
    Bournemouth
    Thanks mate, what's the fix?
    Apr 2012
    Bournemouth
    Also ive had the car plugged in for faults and none are showing or stored?
    Sep 2010
    cornwall
    Trim : SRI
    Mileage : 85000
    high pressure fuel pump will not give faults, it just cant keep up with demand required when trying to rev past 3k, easy to replace but expensive, what make is you pump? is it a seimens or continental
    http://www.ebay.co.uk/itm/Genuine-Va...item35bb5dac90
    Apr 2012
    Bournemouth
    Where can I find the make?, is it repairable?
  1. cuts out
    By daddyjay in forum Engine & Drivetrain
    Last Post: 1st March 2012, 21:42
  2. Engine Cuts Out
    By bulletproofpanda in forum Engine & Drivetrain
    Last Post: 20th September 2010, 20:41
  3. Engine cuts out
    By Lloydy in forum Engine & Drivetrain
    Last Post: 26th May 2010, 12:52
  4. engine cuts out
    By thedhj in forum Engine & Drivetrain
    Last Post: 7th February 2010, 14:07
  5. Engine cuts out
    By Chippie19 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd August 2009, 09:22
