Results 1 to 10 of 11
Thread: Vacuum pump reliability
    Sep 2011
    Caerphilly
    Vehicle : saab 93 tid(150)
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Default Vacuum pump reliability
    (z19dth) whats ppls thoughts/opinions on these vac pumps is it simply they either work or dont work or can they wear and not produce the same vacuum as they should out of curiosity, im planning on testing mine with a vac gauge and compare it with my bro's astra (same engine) again just out of curiosity. Cheers
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Has anyone had or heard of problems with the vac pump?
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    Mines leaking oil at the bottom is that normal?
    PRESTON
    Mine failed internally and was leaking oil into the small turbo vac hose. When i took the old one apart the internal casing was very badly scored. Having said that it had covered 103k. The brakes also felt better when the new one was fitted.
    Regular Member lutonmatt's Avatar
    Feb 2012
    kent
    never heard of any problems
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    Mines done 126k so it probably needs replacing then.
    PRESTON
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Quote Originally Posted by barney490 View Post
    After new pump was fitted did you notice any diff to turbo spool up or boost increase due to having the correct vacuum?
    PRESTON
    The turbo could be heard more after the pump was changed, possibly due to better vac and the fact the pipes were not full of oil. In the how too i posted above, you can see in one of the pics that the small vac pipe was actually sweating oil.
    Nov 2011
    Cheshire
    Vehicle : 1.9CDTi(120)SRi
    Engine : 1.9DT
    Mileage : 100k
    Quote Originally Posted by dan danz View Post
    Why? Are you having vac related issues?
  1. vacuum pump cdti
    By mon in forum Engine & Drivetrain
    Last Post: 23rd January 2013, 09:31
  2. vacuum pipes from pump
    By james walker in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2011, 22:00
  3. vacuum pump
    By Dougb in forum Engine & Drivetrain
    Last Post: 30th June 2010, 22:41
  4. Vacuum Pump 1.9 cdti 120
    By mark230678 in forum Parts for sale
    Last Post: 3rd July 2009, 21:39
  5. EML - Vacuum Pump ?
    By matiny2k in forum Vectra C / Signum Troubleshooting
    Last Post: 30th July 2008, 20:53
z19dth vacuum pump
