Thread: VXR instrument panel?
    Mar 2012
    Hampshire
    Default VXR instrument panel?
    Hi guys,
    I own a 2007 Vectra 2.8T V6 and want to know how hard it is to fit the VXR instrument panel inplace of the regular boring one?
    South West
    About 10 mins work. Only drawback would be mismatch of the milage between your original and the donor. But this can be changed by the right people.
    Have a look in the how to section, i am sure there is step by step guide to remove the instrument cluster.
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Doesn't the milage correct itself eventually as its stored in the ecu?
    Mar 2012
    Hampshire
    Quote Originally Posted by Aidi View Post
    The milage counter is digital and also its seperate to the dials isn't it?
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Quote Originally Posted by leemarksmith View Post
    No mate. The ECU and the speedo hold seperate mileages IYKWIM. If you car was built in Germany the ECU is actually in Kilometers. A few found out they've had clocked cars once the ECU was read, Derek was one, hoochydaddy was another IIRC, because just the speedo was altered.
    Mar 2012
    Hampshire
    Damn :-(
    I dont want mimatched milage so I may just get a VXR sticker and have an LED conversion done to red.
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    Yes but you should be able to get mileage correction done on a set of VXR clocks, dont think its that expensive. You could also just swap the needles and clock fascia over to your own speedo too. I just did this to mine with the dials from a GSi.
    Regular Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    I could give you the number of someone who would do it for you but it would mean a 4hr drive to Bradford for you, or post the said clocks to him for a change in mileage.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Or you could just buy the appropriate replacement front cover for yours http://www.xtuners.com/catalog/index...num-c-26_34_81
    Here's my pre-face ones fitted with the OPC replica panel from this company.
    They're very good quality and are a perfect fit (as long as you make sure you order the right one), downside they are quite expensive and do take about 3 weeks to arrive.
    Mar 2012
    Hampshire
    Quote Originally Posted by Ian-Highlander View Post
    Thats more like it :-) They do a red one which is what I would go for. Would I need to do some LED changing?
  1. Instrument panel
    By copperkettle in forum Electrical & ICE (including SatNav)
    Last Post: 7th June 2012, 15:02
  2. Instrument Panel Indications
    By jimbojetset in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2011, 19:09
  3. My instrument panel cluster is not working
    By bale541 in forum Electrical & ICE (including SatNav)
    Last Post: 20th May 2011, 11:38
  4. Instrument Panel Lighting
    By dc6839 in forum Bodywork & Interior
    Last Post: 29th July 2010, 12:17
  5. Insignia Instrument Panel.
    By Maverick in forum Insignia car chat
    Last Post: 7th June 2008, 13:19
