Thread: EGR removal and clean
    Sep 2009
    Glasgow
    Default EGR removal and clean
    What a difference in low end power after i cleaned out egr, will order semi blanking plate from fiat next time ive got a couple of days off together.
    Nov 2009
    Warrington
    Quote Originally Posted by nokiaman1978 View Post
    Just out of curiosity how many miles has it done?
    Sep 2009
    Glasgow
    75 k mate
    Nov 2010
    East Midlands
    Trim : design
    Easy to make one - I used an old piece of 22mm copper pipe flattened out and used the original gasket as a template with three 6mm holes in the middle. Coppers good to use as its soft and forms a good seal. Here's a picture
    Sep 2009
    Glasgow
    looks good mate, but im sure on the 150 its the other gasket thats needed.
    Nov 2010
    East Midlands
    Trim : design
    Thought it was the same on both - I know the 150 has the large 'square' flange at one end but the other end is the oval shape and thats where the blank plate goes.
    May 2006
    scotland
    I am sure different people have done different things on the 150 wrt which hole to restrict. Some say it is best to restrict the EGR inlet (pipe from exhaust), some say it is best to restrict the EGR outlet (the side that bolts onto the inlet manifold). For me, I just disconnect the EGR electrical connection. My EGR is new and therefore is almost a perfect seal, so no gas into manifold. Will connect it up near to and including MOT time. It does throw the eml light on but no worries for me.
  1. A clean one !
    By markm in forum Insignia car chat
    Last Post: 20th February 2013, 22:27
  2. Help need heater motor removal clean brushes
    By readbri in forum Electrical & ICE (including SatNav)
    Last Post: 5th January 2013, 23:30
  3. Car is clean
    By VectraElite 2.2DTi in forum Vectra C / Signum Car Chat
    Last Post: 1st March 2011, 23:15
  4. How do i clean the maf?
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2008, 17:35
  5. clean car
    By soulman in forum Gallery
    Last Post: 22nd April 2007, 21:24
