Thread: 4 wheel alignment
    Regular Member tangoman's Avatar
    Berinsfield,Oxford
    Vehicle : VXR Estate
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    Default 4 wheel alignment
    Getting the alignment done 2moro at ATS in Oxford.
    Had to replace the rear tyres on Saturday as they were completely
    knackered on the inside edge. Replaced the upper control arms in August
    last year, but anything else causing it. As far as I know its on standard suspension so not lowered at all. Hopefully all going to be ok.
    South east
    I didn't know ATS would do 4-wheel alignment, thought it would be just the fronts. Fair do if they do it though.
    it does say computerised wheel alignment on there website , not sure if its all 4 but can be sure its not going to be a hunters system
    South east
    "Computerised" probably means they use lasers to align the front wheels instead of mirrors.
    11 Post(s)
    Quote Originally Posted by Rebellion View Post
    That's what ATS used to do my tracking (the make of the kit used was called Lazer), and also said the rear suspension was non adjustable, but was aligned correctly anyway. Only time will tell whether my rear tyres go the same way they did before.
    Computerised :
    Mechanic gets out some chalk and a measuring stick
    He then puts the measurements into a calculator
    Writes out an invoice "computerised alignment"
    When you arrive, take a look at the equipment they are going to be using
    If it is SuperTracker it is lasers
    Before they start, ask if they have the display you can watch and if you will receive copies of the before and after reports
    What price have you been quoted?
    What is the postcode of the outlet?
    South east
    The rears are adjustable for camber - but camber is exactly what they don't touch in the standard/boggo two-wheel alignment.
    Having now been to the ATS website, they offer both wheel alignment and computerised alignment
    http://www.atseuromaster.co.uk/retai...-alignment.htm
    For wheel alignment they are clearly doing the front only
    For computerised they are putting your details into a computer and then saving them for future visits, plus you can watch as they adjust
    This does suggest they are using Hunters, or similar
    If it is not Hunters, try to find out whose machine it is
    Jul 2009
    Brighton
    i used ats in hove. They have the hunter machine. Go on the hunter website and do a dealer search. Usually give you a 10% discount voucher.
  1. wheel alignment
    By matt2005 in forum Suspension, Wheels & Brakes
    Last Post: 8th March 2012, 12:32
  2. 4 Wheel Alignment
    By Tam80 in forum Suspension, Wheels & Brakes
    Last Post: 29th January 2011, 20:06
  3. 4 wheel alignment
    By dave_taiho in forum Northern Ireland (RO - Vacant)
    Last Post: 9th March 2010, 16:35
  4. Wheel Alignment?
    By parapaul in forum Suspension, Wheels & Brakes
    Last Post: 23rd November 2008, 23:09
  5. 4 wheel alignment for £40....
    By Stevie-B in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2008, 22:40
