Thread: Rear Control Arm Bush Replacement Made Easy
    South east
    Default Rear Control Arm Bush Replacement Made Easy
    Following on from an earlier thread of mine ( http://www.vectra-c.com/forum/showthread.php?t=159604 ), which confirmed to me that most people had found that only the outer bush was worn on the rear upper control arms when they removed the old part, I decided to try and replace just the outer bushes yesterday, without going to the hassle of removing the arm from the car.
    I used the "threaded rod and nut" method, which I've seen used on Wheeler Dealers, and in fact if you buy la-dee-da new bushes (e.g. ones with camber adjustment facility) then you sometimes get the rod, nut and a metal sleeve included with them. My bushes were from ebay, so I fashioned my own removal parts, i.e. an M12 threaded rod from Wickes and several nuts and washers.
    Attachment 54125
    This method worked a treat, and the outer bush was indeed totally worn - the metal sleeve inside the rubber could be moved up and down by hand, which isn't how it should be.
    The shiny round metal thing in the middle of my bush removal contraption is an exhaust clamp, and it was used to pull the bush into it; the rusty metal thing to the right of it is an old dumbell weight, which has a hole small enough that the 32mm socket to the right of that doesn't slip through - the socket stops the washer on the rod from slipping through. If you had some bigass washers to hand you could do without the weight and the socket, but I didn't have any.
    I reversed the tool to pull the new bush into the control arm afterwards, and job done.
    Regular Member Suffolk Boy's Avatar
    Apr 2008
    NEWMARKET
    Thanks , thats a good tip , mine are bolloxed as shown by knackered inner tread on tyres, will give this ago .
    How much were the bushes ?
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    good job well done , do you have a link for the replacement bush
    South east
    Lots of different price ranges available, here's one at £20 for just one bush:
    http://www.ebay.co.uk/itm/Suspension...item2ebaf36657
    And here's one at £10 for both, or a quarter of the price:
    http://www.ebay.co.uk/itm/VAUXHALL-V...item3a62f8a670
    Apr 2008
    NEWMARKET
    Thats good , better then fitting new arm .
    exeter
    or you can spend more and only replace the once ?. http://www.powerflex.co.uk/products/...29-2690/1.html
    Regular Member Keif's Avatar
    In the Garage
    Quote Originally Posted by reeseandellie View Post
    Cheapest i've found (and fitted)
    http://www.powerflexshop.com/product...oducts_id=2754
    South east
    You still have to remove the old bush and fit the new (Powerflex) one though, as Powerflex don't sell the arms, just the bushes.
    In the Garage
    Yes, you still have to remove the bush, but as you said in your original post, the outer bush wear more than the inner bush. While replacing it with a standard bush will solve any knocking etc you get with worn bushes. Reeseandellie is just saying replace it with a Powerflex bush you only have to do it once.
  1. For Sale: rear upper control arm bush and removal tool
    By marktaylor in forum Parts for sale
    Last Post: 11th December 2012, 11:25
  2. rear lower control arm bush
    By Phil in forum Suspension, Wheels & Brakes
    Last Post: 26th July 2012, 13:32
  3. Rear control arm bush size
    By stevie16v in forum Vectra C / Signum Car Chat
    Last Post: 27th March 2012, 21:56
  4. Rear control arm bush replacement
    By Jock-W in forum Suspension, Wheels & Brakes
    Last Post: 30th January 2012, 14:23
  5. Rear cluster replacement - is it easy?
    By stehanson in forum General Chat
    Last Post: 25th October 2006, 16:53
https:www.vectra-c.comforumshowthread.php161771-Rear-Control-Arm-Bush-Replacement-Made-Easy
trailing arm bushes on vectra c
vectra c rear trailing arm removal
replacing trailing arm bushing vectra
vectra c rear control arm bush removal
vectra c trailing arm bush removal
removing rear trailing arm vectra
how2 replace trailing arm bush on vectra 05
vectra c which size of rear upper bush
what tools needed toreplace upper control arm vectra c
vectra c lower rear arm replacement
