Thread: Metal plate rubbing on brake disc
    Regular Member ph67's Avatar
    Northamptonshire
    Default Metal plate rubbing on brake disc
    I seem to have a recurring problem in the left frontwheel hub - there is a metal (aluminium?) plate next to the the inside facing disc - it touches on the disc and makes an awful screeching or scraping sound when I turn or occasionally when travelling in a straight line, I've been under the car and tried to bend it away from the disc using a screwdriver but it doesn't last long and ends up rubbing on the disc again.
    1. Does anyone else have this issue, if so what do you do to correct it?
    2. What is this metal plate for? Is it some sort of protection to the disc agasint the steering arm bush or against stones?
    Thanks for your help.
    Quote Originally Posted by ph67 View Post
    The latter - a stone guard.
    Nope, never had a problem, other than accidentally bending one once while doing another job. Bent it back and it was fine thereafter.
    Northamptonshire
    Guess I need to take the screwdriver to it again then........
    Jun 2009
    birmingham uk
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Mileage : 106000
    Mine started doing that and on inspection it was corrosion that had built up on the brake disc catching the stone guard, glad it did because from the outside looking through the wheel the disc looked fine but as it turns out bits were 'chipping' away from the disc surface! Needless to say new discs and pads and all good now :-)
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Had this on my daughters Zafira - you should be able to bend it away from the disc quite easily
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    No it's not, it's to protect the lower balljoint rubber against heat from the brake disc.
    I stand corrected. However, why does it need a full shield slightly larger than the brake disc instead of just something covering the lower balljoint.
    edit, while googling, I just found several other answers. Some plausable, some not.
    Dust shield to help stop brake dust entering the engine bay from underneath the car - lol
    Splash shield. Quite possible.
    VOTING UKIP IN AVELEY
    6 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    i always thought they were brakedust shields personally .. lol
    Chelmsford
    A few years ago I got a warning on the MOT saying that the brakes were slightly imbalanced. They did the usual and started saying things about dodgy calipers, fluid changes etc... Bit surprised as I'd recently done a full brake service.
    Jacked the car up and found I too have bent the shield against the disc. Bent it back at all was well (asides from it having taken a couple of mm off my brand new discs!)
    Northamptonshire
    OK - I think the heat shield to the ball joint rubber / stone protector sounds plausible. The discs / pads are new all round as of last July, I'll take a screwdriver to the plate and bend it away a little.
    Corrosion - that's a good point, I recall that from the old set so I'll have a look around the disc edges and scrape it off if there is any.
    Thanks to all. Much appreciated.
  1. How to fit metal tax disc holder?
    By weverall in forum Styling
    Last Post: 6th February 2012, 12:11
  2. brake disc
    By skidmark1 in forum Vectra C / Signum Car Chat
    Last Post: 11th June 2011, 22:28
  3. brake disc etc
    By hoochydady in forum Suspension, Wheels & Brakes
    Last Post: 6th May 2010, 12:41
  4. Brake disc set
    By copperdock in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2008, 09:42
  5. Quick question: Number plate screws: Metal or Plastic???
    By RSV_Ecosse in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2008, 00:09
plate behind brake disc
vauxhall insignia brake dust shield
vectra c brake disc plate
disk back plate catching
vauxhall insignia front shield
dust cover touching brake disc
mercedes cls 320 cdi front brake heat shield rubbing against brake disc
vauxhall insignia front brake shields
rubbing brake shield
remove vauxhall insignia brake dust covers
vectra c rear caliper rubbing
vauxhall combo rear brake protection plate corrosion
dust shield rubbing on brake discs
vectra heat from brakes
twited backing plate catching on disc
insignia brake guard catching
astra brake shield rubbing
vauxhall frontera. brake disc shield
gaurd is rubbing on break disk
disc catching on disc guard
brake guard catching brake disc
insignia bent break shield
https:www.vectra-c.comforumshowthread.php161767-Metal-plate-rubbing-on-brake-disc
stone guard rubbing
