Thread: Releasing hand brake self adjust mech
    Regular Member hagga's Avatar
    kingswinford
    Default Releasing hand brake self adjust mech
    Any one had any experience resetting the self adjusting mechanism?.. manual says push piston/spring back and press down transport fixing to lock but i can't get the piston to go in... starting to lose my rag with it and now fear I will end up finding Mr Haynes and 'with a suitable tool'... poke him in the eye
    Dec 2011
    Seaham
    Dont you need a piston rewind tool for the rear calipers?
    Nottinghamshire
    This sounds like one of those simple jobs that turn into a nightmare, but for once I had no issue with it.
    Why do you need to do this? Have you replaced the handbrake lever assembly or handbrake cables? There's no need to do this if you have replaced the rear disks/pads - just hold the button in and pump the handbrake lever a few times until the self-adjuster has had time to adjust itself fully to the new disks/pads.
    1. Chock the wheels and release the handbrake.
    2. Push rod towards the back of the car. It's stiff (pushing against spring) and hard to get at so I used a long metal bar - inserted into the gap between the front of the rod and the front of the recess that it sits in) to push it with.
    3. Push the metal locking clip down so that it engages. The self-adjusting mechanism is now locked in the 'transport position'.
    To release the mechanism and return the handbrake to normal operation, just pull up the handbrake lever.
    kingswinford
    Quote Originally Posted by Ben50n View Post
    not for mine as they are 4 pot.
    Quote Originally Posted by James24 View Post
    Why do you need to do this? Have you replaced the handbrake lever assembly or handbrake cables? There's no need to do this if you have replaced the rear disks/pads.
    It did start off as just changing the pads.. but then found a seal gone so removed caliper to reseal it.. needed slack in cable to attach cable to caliper.. sorted it now ... there is a sleeve at the rear of piston that should get pushed in when lever is down to disengage ratchet so you can push the piston in... a bit of fudging with a screwdriver sorted it Cheers guys
  1. Hand Brake
    By crispy007 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2013, 18:05
  2. hand brake?
    By ricky1 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2010, 21:59
  3. hand brake slipped
    By VEC-MAN in forum Vectra C / Signum Car Chat
    Last Post: 9th November 2008, 13:41
  4. hand brake
    By JATBOY in forum Suspension, Wheels & Brakes
    Last Post: 4th October 2006, 07:32
  5. hand brake
    By murf2484 in forum Suspension, Wheels & Brakes
    Last Post: 18th June 2006, 11:36
vectra c handbrake self adjuster
how to realise 06 vectra c handbrake
vectra c handbrake reset www.vectra-c.com
resetting handbrake cable on vectra c site:www.vectra-c.com
release handbrake cable adjustment on a 04 vectra
04 signum reset handbrake adjuster new cable
cheap vectra c handbrake self adjuster
