Thread: Rear suspension bush tools ?
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Default Rear suspension bush tools ?
    Been looking over the old posts, but can't see a definitive answer.
    Has anyone bought or seen a puller / press tool for the rear suspension trailing arm bush ?
    All those on e-bay seem to be for Vectra B, as do the catalogues I've found for tool factors online. ( or do these fit ? )
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Bump - anyone ?
    Search on here for
    Rear control arm bush replacement made easy
    Sent from my iPhone using My thumb
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Thanks Mark
    that's always been plan B. Once the bushes turn up I'll search the garage / second hand tool stalls to make a puller up.
    Just wondered if there is the correct bit of kit readily available....
    Dec 2011
    Seaham
    Sometimes can make one out of a socket set and a long bolt.
    South east
    Quote Originally Posted by marktaylor View Post
    Search on here for
    Yup, that's my thread
    http://www.vectra-c.com/forum/showthread.php?t=161771
    It's pretty easy to do.
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Just realised we have wandered onto upper arm bushes - not the trailing arm I'm looking into. Has anyone changed this, and do you know of a tool available off the shelf ?
    If not, I can bodge one together, but hey - if I don't ask....
    South east
    Does the metal in the bush extend either side further than the rubber?
    Regular Member lutonmatt's Avatar
    Feb 2012
    kent
    i would of called that the radius arm bush
  1. Rear suspension bush (lower) How do I change it?
    By Big Dave in forum Suspension, Wheels & Brakes
    Last Post: 2nd December 2016, 12:41
  2. 2005 upper, outer, rear suspension rose bush
    By kbs in forum Suspension, Wheels & Brakes
    Last Post: 8th February 2012, 20:21
  3. rear suspension bush
    By phil0464 in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2010, 22:23
  4. Help - Rear suspension bush
    By john1 in forum Suspension, Wheels & Brakes
    Last Post: 9th October 2009, 21:24
  5. Suspension bush
    By suj786 in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2005, 11:19
