Thread: bulb out light
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default bulb out light
    Is the indicators connect to the fault light on the dash to say you have a bulb out, reason I ask I've just had one go and the bulb out light hasn't come on
    Nov 2009
    N/A
    Quote Originally Posted by chris1804 View Post
    not sure, but don't think so (haven't had one go on my vec yet), most car indicators flash faster if an indicator bulb is gone, which would kind of make turning the warning light on unnecessary
    Vectra-C Enthusiast
    Dec 2011
    Leicester
    Ive had an indicator bulb go, no bulb out warning light just the faster flashing when indicating as mentioned above
    11 Post(s)
    Warns me on mine. When I had the headlights out to fit my HIDs, I put one headlight back in and the bulb check system told me that umpteen bulbs were out. i.e. front fogs - left and right (because I also had the bumper off), front side light, dipped beam, high beam, and indicator.
    Both the light in the speedo housing came on, as well as the stereo display giving graphic representation of each and every bulb.
    Same thing when I changed a rear side/brake light bulb. Tried with the multiplug disconnected from the bulb holder assembly. Told me each and every bulb wasn't working in the light cluster.
    Nov 2010
    East Midlands
    Trim : design
    I keep getting the 'check right reversing light bulb' - keep checking it and its fine
    11 Post(s)
    Quote Originally Posted by alcutler View Post
    Most likely the bulb is on its way out.
    Nov 2010
    East Midlands
    Trim : design
    Thanks for that - I'll get it changed
    Oct 2009
    Sandwell
    So can you use LEDS for the indicators ?
    11 Post(s)
    Vectra-C and LEDs are a bad combination where exterior lights are concerned.
  1. AFL light owners - kerb light bulb upgrade?
    By MCD in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2010, 23:09
  2. Fog Light Bulb
    By rsocon in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2010, 19:29
  3. Can I Replace Fog light Bulb for a 100 watt Bulb
    By m300raj in forum Electrical & ICE (including SatNav)
    Last Post: 17th January 2010, 19:33
  4. light bulb help
    By butcher-boy in forum Electrical & ICE (including SatNav)
    Last Post: 28th January 2009, 00:41
  5. Parking light check bulb light on and wont go off
    By rollercoaster63 in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2008, 12:03
