Thread: Trouble compressing rear caliper
    Regular Member hagga's Avatar
    kingswinford
    Default Trouble compressing rear caliper
    In the process of changing rear pads, passenger side the caliper pistons whiizzed back in with no issues but the drivers side ones wouldn't budge untill i'd opened the bleed (note these are not std calipers so no fangled caliper tools required)... I'd read that this could be a collapsed hose but they're only a couple of years old(braided) and the caliper itself appears to work/release correctly... any ideas?
    Engine : 1.9 CDTi
    The rear pistons need winding back so no idea how you managed to just push the other one back.
    Regular Member Mopar Man's Avatar
    herts
    Not standard calipers Lee
    If Ok with nipple open, it has to be the brake hose. Usualy the brakes would bind, when hot.
    Full Member daddyjay's Avatar
    Jan 2010
    poole
    Vehicle : vectra facelift
    Trim : sri
    Engine : z20net 2oltr turbo
    Year : 57
    Mileage : 38200
    if you dont have a wind back tool use long nose pliers worked for me..
    Feb 2012
    Oldham
    He does state they ain't std calipers..
    Can't help on why it doesn't go back easy tho.
    kingswinford
    Quote Originally Posted by Mopar Man View Post
    they don't seem to be locking in pressure(apart from when i want push the pistons back).. caliper seems to release ok when i come off the pedal.
    Engine : 1.9 CDTi
    What callipers are they as 90% of callipers that use the calliper for the handbrake wind back.
    Others I have seen there is a an Allen key you need to unwind on the back of the calliper.
    kingswinford
    Quote Originally Posted by lee gsi View Post
    they're hi-spec billet 4's (4 pot with cable operated hydraulic hand brake). I asked the manufacturer when i ordered the pads whether it was a simple(or not lol) push pistons back in.
  1. rear caliper
    By roverjay in forum Engine & Drivetrain
    Last Post: 5th January 2013, 17:20
  2. Compressing springs
    By jrh1 in forum Handling & Braking
    Last Post: 27th February 2012, 22:45
  3. rear screen washer trouble
    By dezzie in forum Vectra C / Signum Car Chat
    Last Post: 23rd June 2007, 21:54
vauxhall rear caliper piston trouble winding back
