Results 1 to 2 of 2
Thread: eletronics
    Apr 2012
    cannock
    Default eletronics
    we have a 2003 2dti vectra,we ran it thou a op-com on it has it occasionally came up with a spanner and car symbol and it come up with the following fault codes :
    B3115 -remote key 2 not synchronised (not present)
    B2810 - steering wheel remote circuit open or high voltage (present)
    B0012 - driver airbag (stage 1) high resistance (present)
    BOO13 -driver airbag (stage2) (present)
    U2116-invalid data IPC (instrument) (not present)
    U2139-invalid data CIM (steering column module)
    U2139- invalid data CIM(steering column module)
    B3916 -no communication (not present)
    B3883 - rear licence plate circiut open (present)
    when we went to see the car the battery had been run flat, we had it serviced and was fine,i forgot to shut the boot properly and it it again twice came up with the car and spanner light The car is running fine but when that spanner and car light comes on it cuts off the turbo. we ran another opcom and now say the two top codes but says it has no communication with anything else, we have a abs light on no steering wheel airbag and no buttons work on steering wheel, wondering if anyone one can help us with the codes
    Nov 2009
    N/A
    Quote Originally Posted by charlotte View Post
    First thought would be to check the physical connections between the steering wheel and the rest of the car, I'm not sure if the steering wheel controls run the the CIM or direct, sure someone will elaborate.
    If they all seem ok, next port of call would probably be the CIM itself
