Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: Tickover 1100rpm....
    Regular Member sterie's Avatar
    Nov 2011
    staffs
    Default Tickover 1100rpm....
    Please help if you can!
    My car is a 2003 1.8 Vectra SRI
    For a while now, on occasions i have had a problem with the revs dropping and rising again, at tickover or pulling up to traffic lights the revs would go down to 650 rpm and rise and fall from around 400 rpm to 1200 rpm.
    So i thought i'd give it a go. I thought i would first of all clean the throttle body, it was really gunged up.
    So i cleaned it and put it back together. I noticed straight away that the revs were higher so i thought it might be an air leak i replace the large hose type clip which holds the air pipe onto thge throttle body and i tightened up the bolts holding the throttle body into the maniflod, i broke one snapped it off b****r!
    After trying several main dealers i went to Allvox, a scrapyard at Derby, got the bolts but when i got home they were about 5mm too big, i went to Halfords and bought 4 new bolts put them in and got the car running again. The revs are still too high at 1050/1100 rpm but at least i can drive it.
    Does anyone have any ideas as to why please?
    Also
    There is a metal cylindrical shaped thing on the right hand side of the cyl head (when viewed standing in front of the car) there is a multiplug connected to it, would that be a egr valve?
    Does this engine have an idle control valve?
    Could it be the thermostat causing the high tickover? I ask because the temp rose to 90 when i was in traffic yesterday, i never noticed it do that before, or could it be that the multiplug from the thermostat is not working properly and i need the hard wire fix to do with the multiplug going from that thermostat?.
    Confused and a little outta my depth!
    The car accelerates really well and the economy is good. I have unplugged tha maf and the car will not start when i try it.
    Phew, if you managed to read it all thanks and i'm sorry if i've missed something out.
    Regular Member rayvo-gsi's Avatar
    warrington
    Sounds like air flow meter try unplugging it with engine running and see if it makes any difference.
    Nov 2009
    N/A
    Quote Originally Posted by sterie View Post
    Also
    I used to have a fiesta, which have an idling fault like this!, which was actually down to a sensor for the power steering system. It may seem unrelated, but because ford had placed the pressure sensor for the power steering fluid low and at the front of the car, it was prone to corrosion and failing, this told the ecu there was not enough pressure in the system which caused the ecu to increase the revs. Don't know if there is a similar system in place on the vectra though, might be worth a check
    Nov 2009
    N/A
    Also, just looked at autodata, when cleaning the throttle body, it says to actuate the valve manually 3 to 5 times, I guess you'll have done this anyway, since mans natural reaction when faced with something that moves is to play with it for a bit!!
    Nov 2011
    staffs
    Thanks mungo, do i umplug it while the engine is running or unplug then start the engine?
    If it were the air flow meter would it do anything else like drink fuel like it's going out of fashion? It's still economical according to the dash readout and it drives better than any 1.8 should imho, the acceleration from 60 to erm 80 is really good compared to what it was a week or 2 ago.
    lol i did move the flap a number of times, i don't have a clue how many times but it was held open with some soft plastic whilst i cleaned it.
    I will top up the p/s fluid too, just in case
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Faulty MAF can cause over fueling and then burn out the front Sensor on the outlet mainfold. Unplug the MAF sensor when the car is running and see what happens. A lot of the running issue faults on the 1.8 are caused bya faulty MAF
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Just another note my tickover was goosed and unstable and ran high and then low when my alternator was on its way out, strange I know but true non the less
    Nov 2009
    N/A
    If there is such a system on the vectra (ie a multiplug to a sensor on the power steering system, then a quick inspection should show whether its needs cleaning/replacing), again I'm not sure whether vx do things the same way!!
    Re the MAF, I'm not an expert on these so I'm sure someone will come along with some sound advice
    Nov 2011
    staffs
    I couldn't see a multiplug around what i think is the p/s moter/pump but thanks anyway mate.
    I unplugged tha MAF it made no difference at all to the tickover. I drove it and it drove exactly as it had done after i cleaned the throttle body. The mpg went down to 9 when i floored it in 1st and up to 65 when on the dual carrigeway at 45 mph on a very light throttle. Is that going to be the maf then people?
    warrington
    Certainly sounds like it bud.
  1. 2.0t tickover
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2013, 13:13
  2. Tickover RPM?
    By johnnylegs in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2011, 09:48
  3. Tickover
    By sri150 in forum Engine & Drivetrain
    Last Post: 26th June 2011, 18:47
  4. Low tickover please help
    By alshel in forum Electrical & ICE (including SatNav)
    Last Post: 25th March 2010, 23:05
  5. Tickover
    By ukdesigngroup in forum Vectra C / Signum Troubleshooting
    Last Post: 26th July 2006, 14:31
why does my vectra c tick over at 1100 rpm
why does my vectra c 1.8 idle at 1100rpm
my vectra c seems to idle at 1100rpm
vectra idle 1100 when at operating temperature
