Results 1 to 10 of 13
Thread: just won these if anyone can help lol
    Regular Member Angel1368's Avatar
    Mar 2012
    liverpool
    Default just won these if anyone can help lol
    had to bid on the siggy surrounds is there anyone round my neck of the woods could give a han put em on and ill grease your palm with cash and tea lol
    Full Member
    Nov 2009
    Warrington
    Quote Originally Posted by Angel1368 View Post
    Are these the ones of eBay ? Did it end about 14.00
    Regular Member Dippy-Vx-line Red's Avatar
    Earlston (Scottish Borders)
    These are a doddle to fit...You dont have to take bumper off to do it..A flat blade screwdriver and an old rag behind the screwdriver to stop scratching your bumper..Just prise the old fog surrounds from the bumper working from the outside in..Youll get so far then youll have to cut the plastic weld then just pull all the way out..after that just push the new ones in youll know when they`re home..HTH..
    Mar 2012
    liverpool
    41 quid they where mate, that helps a great deal yes mate i was under the impression my bumper had to come off
    VIP-Member puppet's Avatar
    East Ayrshire
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    As already said, they are fairly easy to fit. Just look at the new ones when you get them, and you'll can see where the clips/tabs are so you know where to disengage the old ones from.
    I fitted them to mine recently, took about 20 mins all in.
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    I took the bumper off and glad I did as I had to use a sharp knife to trim them as they were not a good fit to start with. Probably down to my bumper not being the original item though.
    Good luck with fitting. I would have helped but too far to travel I'm afraid.
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    Well done on tracking a set down mate cheaper than most,was talking to you a few nights back about them
    Regular Member toaffer's Avatar
    Sep 2011
    Fife,Scotland
    Trim : SRI
    Engine : 1.8 VVT (Z18XER)
    Mileage : 73K
    Jeezo! Ive had Siggy F.L.S. sitting for a while now souly due to the fact it was a bumper off job! well if its descent enough next weekend I'll be slapping them on the easy way!
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    I'd take the bumper off if it was me. Last time I swapped some over the new car had had the previous ones glued on from behind for some reason and I had to scrape the glue off to get them off. Would have caused a bit of damage if I'd used the screwdriver approach.
    Mar 2012
    liverpool
    yes patch i decided to go for it, ill try the easy way but knowing my luck itll be a pain in the a55
