Results 1 to 10 of 30
Thread: Inner CV boot?
    Hanging Heaton / Batley
    16 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Default Inner CV boot?
    My O/S is split... Is this an M.O.T fail?
    wirral
    33 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Yes
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Depending on your skills, it's DIY'able
    Did mine a few weeks ago, both inners split
    16 Post(s)
    Mileage : 110k
    What needs disconnecting to get it off?
    I'll happily have a go.
    Nov 2011
    Shock absorber removed (ideally for access, but just disconnected from the hub will do)
    Droplink if removing the shock (as said, it's easier for access)
    Track-rod disconnected from hub
    Best way to do it is to start by taking the wheel off, remove it's centre-cap, then remove the hub nut cover. Put the wheel back on and lower the car back to the ground. 32mm Socket and a ruddy great breaker bar will make removing the hub nut easier, especially with the wheel on the deck to stop it moving
    Only loosen the hub nut a half turn, then jack the car and remove the wheel to remove the hub nut completely (haynes advises not to rest the car on a bearing without the CV joint present and tighened which is why you remove the nut after removing the wheel)
    The rest is simple, plenty of rags to clean any grease that has escaped, and a suitable tool to tighten up the new boot clips.
    16 Post(s)
    Mileage : 110k
    Thanks... Might give it a go next Sunday
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    Or buy the ones that you glue back together when fitted mate much easier
    Nov 2011
    Try www.eurocarparts.co.uk for the part, it's where i got mine for about £9ish. They have 25% off online ordering using promo code APRIL25, and they deliver free
    wirral
    33 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    They don't last very long. As the seem ends up splitting again
    So if you intend on keeping car pay the 5/6 quid extra an but proper boot.
    Be prepared with a soft faced hammer to hit the shaft out of the hub. As it may need some persuasion to get out.
    You'll need pliers similar to these to crimp the new clamps onto boot
    Nov 2011
    Quote Originally Posted by Critch View Post
    The glued ones, or the ECP ones?
  1. CV Boot
    By Tam80 in forum The 'Off Topic' room
    Last Post: 31st August 2011, 08:07
  2. Replies: 2
    Last Post: 21st August 2011, 11:38
vectra 2.2 sri inner cv joint
how to remove 07 vectra inner cv joint
