Thread: Clunking when changing gear - Problem found
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Default Clunking when changing gear - Problem found
    Hi all,
    I have a clunking sound when changing gear (even with engine off and just moving gear stick). I have found the cause - a loose fitting, but the fitting just seems to be worn and i can't tighten anything up. i have attached a few pictures of the part; it's the round PVC linkage thats got lots of slack in it!
    My question is, what's it called and does anyone know how much it is to replace (or have replaced)? It looks like the whole piece will need replacing, not just the link, as the bush is not removable :-(
    Any ideas?
    Cheers, Steve.
    Engine : 1.9 CDTi
    Look like the selector cables for the gearstick/box.
    On another planet
    Engine : 2.0
    Quote Originally Posted by lee gsi View Post
    Yes, it is the selector cable from the gear stick.
    East Ayrshire
    Trim : SRI XP1
    Mine does it aswell, more of a loud click when its engaging. Would be interested to see if anyone has a fix for it
    On another planet
    Engine : 2.0
    Quote Originally Posted by stevie16v View Post
    Yep, thats what happens to mine. The problem is that the pin that goes through the linkage is not removable, otherwise i would just stick a long M8 bolt though the lot. If it gets too bad (falls off completely) i may try to snap the pin out and put a bolt through the hole left. As otherwise it looks like a job to replace the lot..
    East Ayrshire
    Trim : SRI XP1
    Seems like an awful lot of hassle. I might spend a bit of time next week having a look at it, see if I can think up a fix
    Engine : 1.9 CDTi
    Could you not wrap some tape around the pin it fits over so it makes the pin 'bigger'
    exactly what lee says
    duct tape the pin so that the bush it stiff to get on
  1. Clunking from front when changing gear!
    By SmiffyMan in forum Engine & Drivetrain
    Last Post: 8th July 2012, 22:53
  2. Found a small bit of tissue when changing suspected fuel pump
    By rollercoaster63 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd November 2011, 20:44
  3. not changing gear !!!!
    By bert01909 in forum Engine & Drivetrain
    Last Post: 20th September 2011, 19:37
  4. changing the gear knob
    By jamie_hepp in forum Bodywork & Interior
    Last Post: 12th April 2011, 22:12
  5. Trouble changing gear
    By jwturpin in forum Engine & Drivetrain
    Last Post: 23rd May 2009, 19:56
vectra c gear selector problem
clunking noise on vectra when gear changing
vectra c change gear and there is a clunk
vayxhall vectra 1.9 cdti clunking in to gear
insignia 1.8 clunk sound changing gears
corsa c clunk noise changing gear
vauxhall insignia clunk between gears
vectra c slack gears
vectra c making noise when you change gear
insignia noise when changing gear
knock when changing gear corsa c
theres clunking on my corsa cdti when i change gear
how to change gear selector cable vecta c 1.9cdti 2006
insignia clunk when changing gear
