Thread: Irmscher Spring Replacement
    Kildary, Highland
    Default Irmscher Spring Replacement
    I've just removed one of the rear springs on the IS3 Signum to get at the upper control arms (new bushes) and found the spring has broken - just sailed through the MOT a couple of weeks ago! So, MORE EXPENSE!
    Question is what to replace them with.
    Ideally Irmscher to keep it all the way it was but even just a pair of rears are £210!!! Whole sets of other makes are available for much less and then I'd have spare fronts for when they go.
    What do you think of Eibach, Spax and PI which are cheaper. Any other suggestions - scoured the internet to see if I could get any pairs of rears but lowering springs are only sold in full sets.
    Any help and advice would be much appreciated.
    Full Member Big Sig's Avatar
    Iirc irmscher springs are just rebranded Eibach's.
    Regular Member james chambers's Avatar
    Sunny Leicestershire
    Trim : SRI
    Engine : Y22SE
    Mileage : 100,000
    Thats right, I have Eibach's on my vectra, there goood!
    Jan 2006
    Dalriada
    H&R's Andrew, got Eibachs on mine but not overly impressed TBH. Would you need stiffer/stronger ones due to towing the 'van??
    Kildary, Highland
    Quote Originally Posted by Steven View Post
    You're probably right Steven that it's been the towing which has weakened them. I'll look into H&Rs.
  1. Front spring replacement
    By maz in forum Suspension, Wheels & Brakes
    Last Post: 11th November 2012, 01:08
  2. rear spring replacement
    By flimbyx1 in forum Suspension, Wheels & Brakes
    Last Post: 19th April 2012, 13:30
  3. spring replacement afl light now flashing
    By iceeee in forum Suspension, Wheels & Brakes
    Last Post: 24th February 2012, 18:06
  4. rear spring replacement
    By meathead in forum Suspension, Wheels & Brakes
    Last Post: 17th January 2010, 04:49
