Thread: Chrome Problems!
    Mar 2012
    Ireland (Kildare)
    Default Chrome Problems!
    Hi, i sanded, primed and sprayed metal chrome coloured bits on my car, left 12 hours after painting before lacquering... When i sprayed the lacquer its as if it reacted as it seemed to fizz before settling. all pain was acrylic and from the same manufacturer!
    Any Ideas?
    Regular Member shinyb1's Avatar
    Jul 2011
    wigan
    where did you leave it to dry . i made a mistake a while ago i painted a wing mirror and while it was drying i cleaned the car and the silicone spray must of blown into the garage . when i went to spray the laquer it reacted .
    Mar 2012
    Ireland (Kildare)
    It was the chrome exhaust tips. Left them on the car as i couldnt remove.
    VIP-Member Z80's Avatar
    Apr 2008
    Noumea
    14 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    Cheap "chrome" spray paint is for interior decoration only and can't be lacquered.
    It will always react and make some ugly yellowish result.
    The only solution for exhaust tips is actually electro-plating with real chrome. You should be able to find someone in your area doing chrome plating for Harley-Davidson bikes, for instance. I don't have this possibility on my island, though.
    On plastics or other less stressed parts, there are a number of methods allowing to achieve an acceptable chrome effect, involving a black undercoating then a semi-transparent silver finish, check Google for "chrome paint", you'll find a lot of information.
    A company in the U.S. (Mirrachrome) has managed to create a real chrome paint, but it's very expensive ($ 1,500 one gallon LMAO), and not sure how it would behave on exhaust tips, with the involved heat.
  1. Replies: 11
    Last Post: 1st August 2012, 12:49
  2. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  3. Chrome grill problems
    By Neil71 in forum Insignia car chat
    Last Post: 7th May 2011, 10:38
  4. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
