Results 1 to 10 of 30
Thread: Do you think these would fit my signum ?
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    Default Do you think these would fit my signum ?
    Hi guys keep looking ar these Irmscher alloys and do you think they would fit my v6 cdti signum the adverts says they are et30 which I'm not sure about http://www.ebay.co.uk/itm/4-x-Vauxha...f#ht_514wt_922
    scottish region
    Maybe need spacers mate
    Regular Member 4ndy's Avatar
    Oct 2010
    Glasgow
    They will stick out 21mm more than your standard wheels but will have the same clearance on the inside of the arches.
    I would only imagine it would cause an issue if the car was lowered beyond standard.
    Oct 2010
    Glasgow
    Quote Originally Posted by DAVIDD88 View Post
    Spacers will cause them to stick out more which should be avoided if you want to reduce the risk of fouling the arches.
    Trim : vxr
    Mileage : 31000
    Seem a decent price when they have Michelin pilot sports fitted might put an offer on them
    Oct 2010
    Glasgow
    Quote Originally Posted by david-bell View Post
    Good size tyre as well. Most 18's come with 225/40/18 which puts the speedo at 60mph short by 1mph but the 235/40/18 is much closer at only 0.3mph slower.
    Regular Member russ1969's Avatar
    Worthing
    Quote Originally Posted by greenleprechaun View Post
    Why would the width of the tyre change the speedo?
    225 is the width
    40 is the profile (which can effect the speedo)
    18 is the diameter
    My standard alloys from Vauxhall are 225/45/18 which is in the book
    Regular Member sterie's Avatar
    Nov 2011
    staffs
    It affects the speedo because the sidewall is 40% of the width of the tread, so 40% of 225 is less than 40% of 235 mate, basically the 235 is very close to the std. sidewall height and gives a very similar rolling radius to std.
    Regular Member Grimy's Avatar
    They should fit no problem. I'm running the same Irmscher sportstars on my signum, all be it mine are 8j x 18" - ET35. I have 235/40/18 tyres too.
    Standard snowflakes are 8j x 19" and have an offset of ET43, so your only talking 13mm differance, and 5mm more than what I'm running. Ive just had another quick look at mine, and Ive loads of clearance yet. Easily squeeze another 5mm in there
    For the money they are asking, and the quality tyres, I'd take their hand off. That said, i'm going to refit the snowflakes soon. The sportstars were off my old astra coupe and were only fitted for the winter whislt I sourced a replacment snowflake due to a crack. The sportstars look good, but dont look very big? might just be me? They looked flipping fantastic on my coupe, but the signum dosent pull them off quite as well.
    Id post a pic of mine, but its dark out and I dont have one on file. If you still want one tomorrow just say.
    Trim : vxr
    Mileage : 31000
    Quote Originally Posted by Grimy View Post
    You got any photos of them fitted mate ?
  1. Replies: 2
    Last Post: 6th October 2012, 23:09
  2. Replies: 5
    Last Post: 5th February 2012, 20:42
