Thread: Advice on Mileage in Diesel Signum
    Regular Member messermitch's Avatar
    Aug 2009
    Yorkshire
    Engine : 1.9Cdti 150
    Default Advice on Mileage in Diesel Signum
    Hiya Folks, well by my calculations, i should have enough money by around the middle of next month to go buy me new motor. I have decided (Almost) that I'm going for the 1.9Cdti 150 model.
    The question i have is about mileage, now i aint gonna have a fortune to spend, im probably looking at around £3200 or thereabouts, depending on the next paypacket. Now iv seen some nice looking motors, but with a lot of em been reps cars, there high milers... Should i be bothered about this? Im obviously looking for service history but i dont wanna be hit with a car that might die...
    How long do these engines go for with good service history?
    Any advice greatly appreciated, as always
    Cheers.. Mitch. Soon to be Signum Mitch! Cant chuffing wait!!!!!!!
    Administrator plasma's Avatar
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    Main points i can think of is,
    1. Check the DMF, listen for rattles, etc, if they go its about £600-£700 to replace
    2. Check to see if inlet manifold replaced.. thats another expensive job.
    3. Check injector wiring plugs, see if yellow or blue... blue is good yellow is bad.. not an expensive thing to fix
    I'm sure others will add to the list of what to check...
    btw, mines on 230k now, flywheel rattles a bit was changed at 100k or so,
    showcar is on 70k
    Regular Member lutonmatt's Avatar
    Feb 2012
    kent
    when i was looking for mine i was looking lowish miles so it had a few miles left in the flywheel or go over 100k for one thats already been done
    normaly i dont care about the miles as my astra has 206k on the clock at the min from a 1.6 petrol and my landrover 186k
    but i was not in a rush to buy and did want a elite so waiting a week and one come up and was local with 60k and auto so dont have to worry about the flywheel
    plus its a fully packed elite
    Aug 2009
    Yorkshire
    Quote Originally Posted by plasma View Post
    showcar is on 70k
    Wow, 230K, that makes the 135K one iv seen look like a low miler!!!
    Thanks for the advice mate.
    Quote Originally Posted by lutonmatt View Post
    I think im gonna try get the Elite but dont think i couldn't drive an auto!
    Do Flywheels usually go around 100k?
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    some go earlier some go later, key is to listen to it... if you test drive and blip the throttle you can hear a rumble type noise on the run down of the engine, or if you've been accelerating and then back off you can hear it then... Also in neutral if its pretty bad you can hear it but if you dip the clutch it disappears..
  1. Low mileage diesel drivers may be wasting their money
    By vectra ste in forum General Motoring Chat
    Last Post: 24th April 2012, 07:57
  2. V6 3.0 diesel 2005 Belt change mileage
    By NPS in forum Engine & Drivetrain
    Last Post: 10th April 2011, 16:48
  3. Diesel Mileage
    By Big Sig in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2008, 20:42
  4. What's the maxium mileage a diesel engine can do
    By rollercoaster63 in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2007, 10:02
