Thread: Headlight Purchase ISSUE
    Regular Member Elahi_786's Avatar
    Oct 2010
    Bedford
    Exclamation Headlight Purchase ISSUE
    I purchased via Ebay used SRI Headlights (Pre Facelift) Seller used them for less then 3 months (newly purchased by him Oem dont look genuine)
    I realised the the projector ball is not sitting in the housing at all, you can see around and inside the projector housing into the headlight. Would I need to take the headlight apart to fix this problem? Can it be fixed I tried giving it a wedge with a headlight inside it and would move but not settle inside the house as in a good fit as it seems like it needs to be placed within it
    Can someone help / does this require removing the headlight and making sure the projector is fitted ?
    This is the problem with both headlights ones worse then the other and its with the adapter in and obviously with it out its worse
    Admin plasma's Avatar
    On the Forum
    271 Post(s)
    Engine : 150
    Mileage : 74000
    photos of the problem?
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Why not send them back?
    Oct 2010
    Bedford
    Going to a little hard as my Iphone is in for repairs only Camera I have.
    To explain myself again - The projector ( Ball ) is not a nice fit around the housing. If you look at the headlight you can see the top right had corner above the housing itself and you can see around quite clearly into the headlight when look at the headlight
    Oct 2010
    Bedford
    Thumbs up
    I have e-mailed him today and asked for more then a 50% refund or to arrange delivery and pay in full.
    Oct 2010
    Bedford
    As the item was sold under ''VERY GOOD CONDITION''.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Is the headlight alignment motor fitted? When this is fitted correctly is stops the inside moving. Not sure this is your issue but lost without pics
    Oct 2010
    Bedford
    It is fitted and removed as well I understood when removed its all loose but even with the motor in place its custom place is not right
  1. Dash/headlight/electricals issue.
    By Keif in forum General Motoring Chat
    Last Post: 15th February 2012, 10:59
  2. AFL headlight issue - levelling
    By tox in forum Electrical & ICE (including SatNav)
    Last Post: 1st June 2010, 14:45
  3. Headlight issue
    By osidda1 in forum Vectra C / Signum Troubleshooting
    Last Post: 5th April 2010, 17:43
  4. Possible purchase
    By Photog Dave in forum General Chat
    Last Post: 27th January 2009, 21:51
  5. Reconsidering Vectra purchase: Handbrake issue
    By izonoky in forum Vectra C / Signum Car Chat
    Last Post: 18th September 2007, 21:00
