Results 1 to 10 of 23
Thread: Vauxhall Signum 2.0L DTi (Elegance) Problem's!
    Apr 2012
    Ma Hoose!
    Default Vauxhall Signum 2.0L DTi (Elegance) Problem's!
    Hi All,
    Was wondering if I could draw on your collective experience, I have spent the last 24hrs absorbing everything I could on here
    about this problem... so here goes...
    I got a call from my dad yesterday to ask me if the quote given to him by his local vx dealership sounded right to me, first off I am no mechanic but have done
    my fair share of self maintenance and modding on my cars growing up without any major c**k-ups! (Never worked on a turbo tho!)
    Since getting his call and the frankly ball clenching quote, I told him to get the car back pronto and I brought forward my visit to the folk's and arrived at the
    cars location yesterday evening with the intention of sorting it for them.
    Anyway, as I say, the car belongs to my parents, which they bought from vauxhall as a treat (lol) when they retired. The car was less than a year old and had been used
    as a demo apparently.
    I've listed all of the stats I know about the car and this problem, below.
    Vehicle Detail's...
    Vehicle: Vauxhall Signum 2.0L DTi (Elegance)
    Engine Model: Y20DTH
    Registration Date: March 2005
    Purchased as 2nd owner...
    Purchase Date: February 2006
    Mileage @ Purchase Date: 7,010 k
    Current Mileage: 54,201 k
    Problem Description...
    Firstly, the car does little mileage (which I know can be a bad thing), they have done approx 47k in 6 yrs, less than 8k per yr.
    My dad says that the car was fine until about 2 yrs ago, then one day they had the dreaded spanner followed by limp home mode occurring while driving up hill,
    (which frightened the hell out of them).
    He has always took it to the local vx stealers and at that time they just serviced it, cleared the codes and problem solved.
    Since then the periodic pattern has been; spanner light & limp mode, vx stealers investigate, take a pile of cash off my folks (which seems to increase each time), they say its
    fixed, short while later the problem reoccurs and the cycle of seperating cash from owner starts again, lol.
    Not this time!
    A month ago, the problem reoccurred while they where in a remote spot, which ended in them calling the AA, the AA guy did roadside diagnostics, cleared the codes and
    cleaned some points which got them home.
    Here's the write-up from the AA guy's report;
    AA Roadside Diagnostic Result's! (@ 52,448k)
    P0100+ - Mass volume airflow 'A' circuit.
    P0105 - Manifold absolute pressure sensor/ Barometric pressure circuit.
    P0234+ - Turbocharger overboost.
    P1105+ - Barometric pressure (baro) sensor.
    AA Inspector's Note's!
    * Checked vacuum pipes etc - OK
    * Found some form of silicon around the Barometric sensor plug.
    Cleaned the plug and sensor with switch cleaner and erased the fault codes.
    * Road tested OK.
    The morning after this it was taken to the stealers (as per the established cycle, lol) and they fit a new airflow component (circa £200), 5 days later... guess what happened!
    Yep, you guessed it, Spanner light constant, accompanied by limp mode... if left sometimes things would clear initially but anything over 15-20 mile range and it returns!
    So, it was booked into vx stealers once again... the dealership rang them after the inspection and said the EGR Valve had gone and it would need to be replaced, they
    said they would order the part and fit...
    Cost: £487.64
    (Hmmm are we in the countryside... cos I can smell Bull$h1t!)
    Thats the point at which he called me before agreeing.
    I took a quick pic of the engine bay so you guys know exactly whats what... spec and config wise...
    Sooo... what do you guys think???
    Regards,
    Jack.
    PS: Will be taken a closer look and clean of the car so will later update later when I drop in to view your guy's thought on this!
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    First thing to do is forget the stealers they will go through the motions of changing parts at your expense until they hit lucky. It seams to me that the throttle body could be at fault. However before spending loads of cash do the simple stuff first.
    Change your vacuum pipe work for new silicone pipe this only costs a couple of quid from ebay. This will eradicate any possible splits you may have that can be impossible to detect.
    inspect your inter-cooler pipe for splits or ware. when the car is in boost ie going up a hill these can expand and open up any hidden splits causing the limp home mode to kick in.
    next thing is to clean your egr valve and inlet manifold.
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    plus if that dosent cure it you could try and adjust the turbo actuator rod , i think you have to shorten it a wee bit , someone here had to do that but i cant remember who
    also ask did the car get the ecu update from the dealers which i think was f.o.c
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    And maybe the next thing is IF you tell us where abouts you are in the world (I cant find 'Ma hoose' on Google maps), then maybe somebody local might offer to help.
    wirral
    42 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Egr valve or wastegate stuck I'd say
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Quote Originally Posted by TonyP2020 View Post
    3.2 v6 Signum and loving it
    Apr 2012
    Ma Hoose!
    @TonyP2020 - Keep your pants on... (Joking...re your avatar)
    Nice of you and Johnsdutton to think that way, had it been my car at my location I would have but its neither and when I registered my dad was like... grumble, grumble, ****** internet won't help me..lol.
    Buuuttt, I think he's starting to change his mind after the results (will post them now) so I think He will probably be joining soon!
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    I know what you mean, a lot of the oldies are scared they will be ripped off, or someone will brake into the house at night and do umentionable things to them and their wives then steal the car.
    Apr 2012
    Ma Hoose!
    Default Update!
    DTI-Steve... its looks like you nailed it before I could even get back on here!
    My dad reckons the number of times its been in with the symptoms must be approaching double figures, after reading up on this forum I took the engine cover off, had a rummage in the engine bay beginning with the intercooler hoses and literally within the first minute, BINGO!...
    1st Hose (drivers side, front corner of the engine bay) 3 tears in the underside of the Hose (1 is an inch and 1/4 ish, flanked by 2 smaller ones!)
    I was speechless!
    Whats th going rate to be a VX Tech?
    Apr 2012
    Ma Hoose!
    @Johnsdutton - Ha... with the exception of a few expletives that is almost word for word Mate!
  1. For Sale: Vauxhall Alloys from Vectra C Elegance
    By Ann in forum Parts for sale
    Last Post: 9th July 2012, 19:21
  2. vauxhall vectra elegance '52 reg
    By rob81 in forum Engine & Drivetrain
    Last Post: 15th June 2011, 14:55
  3. my 2005 vauxhall signum 'elegance' 2.0 DTI
    By martinhill in forum Cars for sale
    Last Post: 19th February 2010, 14:19
  4. Signum 2.0 T Elegance
    By The-Bandit in forum Cars for sale
    Last Post: 12th April 2008, 06:51
  5. Signum 2.0 T Elegance 04/04
    By Staceyboy in forum Cars for sale
    Last Post: 19th September 2007, 09:06
