Thread: Open/closed loop question?
    Sep 2011
    Caerphilly
    Vehicle : saab 93 tid(150)
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Default Open/closed loop question?
    (z19dth). I know on first start up the engine runs in open loop but Does anyone know at what temperature the ecu is suppose to go into closed loop operation? Cheers
    Feb 2011
    Selby
    Not sure it's entirely based on coolant temperature alone. I think there's also a fixed time delay (although only a couple of seconds), and probably the lambda sensor voltages (ie indicating that they have heated up to their working temperature) are used.
    But I'll plug my EOBD reader in this weekend and watch the coolant temperature and report back if you like- though I have a petrol Z18XE so it won't necessarily be the same as yours.
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Quote Originally Posted by rich r View Post
    Cheers fella, but how do you tell on your code reader when it switches to closed loop? ( out of curiosity)
    Feb 2011
    Selby
    I can do real time monitoring of various parameters, rpm, temperatures, O2, trims, ignition advance etc.
    It's just a £10 USB ODB2/EOBD job off ebay with some free Scantool software.
  1. driver,s door closed but dash light says door is open
    By wulza in forum Electrical & ICE (including SatNav)
    Last Post: 21st March 2012, 01:47
  2. As the MOD closed that last thread i will open this
    By RMDveccy in forum The 'Off Topic' room
    Last Post: 7th June 2009, 15:55
  3. In the Loop
    By Stevel in forum The 'Off Topic' room
    Last Post: 24th April 2009, 22:57
  4. A Attack Helicopter doing a loop to loop
    By chrisgettings in forum The 'Off Topic' room
    Last Post: 5th October 2008, 21:01
vectra c not in closed loop
vectra c open loop
